2020GraniteBH
- Oct 14, 2019
Thank you all appreciate the help!!!
That is correct!My build sheet just says "conventional differential rear axle" so just to confirm this mean that I DO NOT need the friction additive when I change the diff fluid correct? Thanks again for all the help as this is all new to me, I really appreciate it!
Thank you!That is correct!
The manual calls for 75W90 for all front diffsDo ya know why Amsoil recommend Severe Gear 75W90 for the front? I got 3.92
Only the 3.92 rear calls for 75w140
True, but the question was about the front diff. Its 75w90 in the front no matter what gears you have.
Yeah...I almost did that to be exactly correct...Honestly it's not going to make any difference anyways.Manual calls for 75W85 in the front diff.
75W90 likely works just as well.
nevermind, I can't read y'all lol. I must of skimmed over the "conventional rear axle"![]()
You are correct. The e-locner does not require the friction modifierNot to bring up a old topic. I have a elocking 392 rear. If I’m reading the chart correctly that doesn’t get the friction additive? Is that correct?
