- Feb 24, 2018
- Solutions
- 1
- Location
- Central Pennsylvania
I jus trealized I posted the wrong thing...Iam trying to pretend like i care to work lol
Do you have a link that shows that Heavy-duty engine cooling includes transmission cooling?The other thread was about heavy duty engine cooling...but that also includes the transmission cooler...standard on all 5.7l Hemi trucks
Yes. I will post it in a few.Do you have a link that shows that Heavy-duty engine cooling includes transmission cooling?
Personally, I've been frustrated at the level of digging required to get into detailed specifications and design characteristics of the HEMI engine and the "upgraded" TorqueFlite 8HP75. Part of my background is engineering, and I'm curious...Yes, it is. It is standard. I can not find anything that spells it out completely to satisfy his question.
5.7l Hemi V8 comes standard with Heavy duty engine cooling and transmission oil cooler
That is stated everywhere...but I can not find a guide that specifically call out the transmission oil cooler.
I can show that the max tow package does not list a transmission cooler as it is standard.
I can guarentee beyond a shadow of a doubt it is standard, but i can not find the exact wording to prove this per say.
Lots of articles state it and personal experience proves it...but I cannot find a feature guide that calls it out specifically
I’m looking to place an order and I’m not sure of which gear ratio to order. 95% of the time I will be driving the truck empty. Gas mileage is important to me so I’m ordering the e-torque engine. I tow a small trailer that weighs 4000 lbs and only do it 6-8 weekends a year.
My concern is that the 3.92 gear is going to kill the gas mileage. The 3.21 just seems a bit low for a truck of this size.
Looking for the mpg difference between the two in every day driving.
Thanks
Today's Ram 1500 employs a production-first thermal management system that taps into heated engine coolant to speed up the warmup of automatic transmission fluid and engine oil to maximize the fuel saving benefits of those fluids.
The 2019 Ram 1500 continues to use the thermal management system to bring the transmission fluid and engine oil to operating temperature quickly. The system also serves a cooling function under high load/high ambient temperature conditions to ensure the transmission fluid temperature is controlled.
Came across that link a few times, and it was probably the best overall summary of the truck's features. You can also find it on FCA's site: http://media.fcanorthamerica.com/newsrelease.do?id=18755&mid=. This still doesn't explain details about how that system works (i.e. "thermal management system") or on which trims/configurations it is applicable.
Thermal management
The Ram 1500 employs a thermal management system that taps into heated engine coolant to speed up the warmup of the automatic transmission fluid and engine oil to maximize the fuel-saving benefits of those fluids.
The engine control unit manages a three-way valve in the engine cooling circuit. Heating the truck cabin always takes priority, based on the HVAC temperature setting. The 2019 Ram 1500 uses the thermal management system to bring the transmission fluid and engine oil to operating temperature quickly. The system also serves a cooling function under high-load/high-ambient temperature conditions to ensure the transmission fluid temperature is controlled.
I disagree; current reviews already show that the tranny runs at the high end of its temp range under load, so to increase that load I think you would need to pair that 6.4l to a higher gear or a heavier duty tranny.
Between which vehicles? The V6 uses a different transmission than the HEMI in the DT, and the HEMI transmission (8HP75) has been revised for the DT.My understanding is the transmission are the same?
The 5.7 in the hd 2500 and 5,7 in the 1500 to my understanding is same transmissions cooled the exact same way.Between which vehicles? The V6 uses a different transmission than the HEMI in the DT, and the HEMI transmission (8HP75) has been revised for the DT.
I can’t speak for the cooling. And aside from more advanced programming (e.g. 40+ shift maps, etc.), I’d like to see more information on the “upgrades” to the transmission in the DT. If there have been no mechanical changes, then the two transmissions may be fundamentally the same. Otherwise, they’re two different generations.The 5.7 in the hd 2500 and 5,7 in the 1500 to my understanding is same transmissions cooled the exact same way.
It's a new transmission (8HP75 vs. 8HP70). But it took a lot of digging to understand what that last digit means...great thoughts....not sure upgrades either on the DT if any.
