A little late to the party, but will throw my hat into the ring also. Just bought a Limited with the e-torque and 3.92's in December in Tucson, and just returned to Washington state a coupe of weeks ago. I am pulling a 9000lb fifth wheel, up to Vegas, Bakersfield, Portland, The Dalles, and over the pass to central Washington. Totaled about 3000mi, over hill and dale, and averaged just over 10mpg. On the flats it was up to around 12-13, but on the long hills dropped to about 3-4, but overall average was 10-11. This is calculated mpg, not truc computed, although I did notice that the truck and my figures were within a couple of tenths. Speeds were in the 50-60 range on the trip, with the occasional fast passing, but kept it at a comfortable speed. I will say that towing with a softer suspension than what I am used to took some getting used to, the truck did exceptionally well, and the softer ride is a welcome change for me as I get older and stiffer. I think that a lower rearend would work well in flats and low hills, but I would go with the higher(3.92) if you spend a lot of time in higher hills and mountain terrain. When running empty, I wish I had the lower rearend for better mileage, but can still get decent mpg if I keep the speed down. Whatever you get, enjoy. You will be getting a grate truck.
