AtlasRam1500
- Oct 23, 2018
2019 limited with 43000k miles no problems with the air suspension
Someone else can correct me if I'm missing something.Hello everyone,
I need some advice. I own a 2021 RAM 1500DT Limited. Recently, I purchased a 22-foot double-axle caravan with a tare weight of 3.3 tons and an ATM of 4.5 tons. The tow ball mass is 250 kg when unladen. When I towed my caravan for the first time, I felt a floating sensation at the steering wheel, as if the front wheels of the RAM were not really touching the road. Starting at 90 km/h, the caravan began to sway dangerously. So, I decided to have it weighed (I am attaching the results Dec 23) and was very surprised. With the car unladen, I had 2000 kg on the rear axle, while the tow ball only weighed 280 kg, and the front of the car seemed very light with only 1460 kg. It seemed as though the rear airbags couldn't support the weight of the tow ball. I measured the distance from the ground to the tow ball, which was 530 mm. My first instinct was to think that I was carrying the caravan too high.
So, I lowered it to 450 mm, making sure the caravan remained perfectly horizontal, and went back to have it weighed. On the road, the caravan behaved much better, with no swaying. The steering feel is also better. However, I was very surprised to see that the weight distribution of the RAM had hardly changed (I am attaching the results Jan 24). I ended up with an illegal overload of 150 kg on the rear axle, while I only had 280 kg on the tow ball (even though the maximum allowed on the tow ball is 450 kg). Could someone explain this to me? Do I have a problem with my rear suspensions?
He has 89lbs payload. What will a WDH do for him? Look at his attachments.Something is off in your weight assumptions. Also, it is not stated if a WDH is being used, which it definitely should be fir that setup. Also, engine and gears are not mentioned, so, check the attached table and see where you are in the listing, and gat a WDH.
. https://www.ramtrucks.com/BodyBuilder/service/Image?imageId=MtQrP/FqLY5r/est8MtGjGgHzAHGUTU0WB3rWuqSY7YmQ2vEhuBWBONjPJTiLoD5
Wrong payload #.He has 89lbs payload. What will a WDH do for him? Look at his attachments.
There are no Limiteds made that have a 2000lbs payload. He also has an attachment showing his base weight of his truck with nothing hooked up is over 7000lbs. No way he has payload for that.Wrong payload #.
These numbers are incorrect. No Limited can have a Payload of 2kSomething is off in your weight assumptions. Also, it is not stated if a WDH is being used, which it definitely should be fir that setup. Also, engine and gears are not mentioned, so, check the attached table and see where you are in the listing, and gat a WDH.
Also, the weight of a 2021 Limited should be 5,345 to 5,568 lbs., so with a GVWR of your 7800#, that would give a capacity of over 2000#, which is also incorrect. Load capacity on my Limited is only about 1400#, and it is loaded.
Don't argue with me. Argue with FCA. They gave the numbers. And like I said, my payload is 1400#.These numbers are incorrect. No Limited can have a Payload of 2k
You don't understand the numbers.Don't argue with me. Argue with FCA. They gave the numbers. And like I said, my payload is 1400#.
And ,tow is rated at 11k and change. Your stated payload of less than 100# is way off.
And no, there is no Limited with a 2000# rating. I also don't know what his truck is made of, but Limited's are specked at 5,345 to 5,568 lbs. dry, so don't know where the 7011 dry weight came from unless he has 2000# upgrade that has been added somewhere along the line.
If his truck weighs that much then he has a 2500. And if that is the case, then he had a payload on 1500 to 4000#, depending on options.Correct
His Gross Vehicle Weight Rating is 7100 lbs.
His truck weighs 7011 lbs meaning his payload is 89 lbs
Do YOU know what it is?Do you happen to know what GVWR means? It in GROSS, meaning INCLUDING PAYLOAD. What part of base weight ( the weight of the unloaded truck) and GROSS Weight the loaded weight of the truck)
being two different things don't you get. Read the summery. The boxed is base weight, and the last one is GVWR weight, ie, combined weight.
That's what I said. But if his truck weighs 700 then he has a 2500, not a 1500Do YOU know what it is?
YOU seem very confused.
The person weighted their truck WITHOUT THE TRAILER HOOKED UP and it is 7011 lbs.
Their GVWR is 7100 for the truck thus their payload is the remaining 89 lbs. In this case that payload is 100% for the tongue weight, which is not enough for a trailer that weighs 7500 lbs.
"The Gross Vehicle Weight Rating is the maximum total safe weight of your vehicle, counting the curb weight (the weight of our vehicle when empty), plus the weight of your passengers, fuel, any accessories added to the vehicle, cargo, and the “tongue weight” of a tow trailer (normally 10-20% of the combined tow load and trailer weight)."
His very first line was this.That's what I said. But if his truck weighs 700 then he has a 2500, not a 1500
Sounds like a leak.I have a 2019 Rebel with 155k and experiencing the same air suspension failure I’ve seen posted at the beginning of this thread (front end dropped / rear holding height). I bought truck new, compressor went out at 80k, had dealer replace it with new OEM compressor. I have not had any issues since until now.
I typically leave it in aero mode and never adjust ride height manually. I live in Indiana and we’ve been experiencing some below normal cold temps. Two days ago, when I walked outside to get in my truck to go to work, the front had dropped over night but the rear remained at what appears to be normal height. I got in and the “service air suspension immediately” warning was on the dash. I let truck run for awhile and went back out and tried again and got something like “air suspension is temporary disabled and cooling.”
I pulled truck into garage and let sit for a few hours in the heat and went back out and tried again, compressor kicked on but would not raise front end. After multiple attempts I unhooked battery, let set one hour, same result. Searched for obvious air leaks and can’t find anything. Jacked front end up to get under truck, compressor kicked on so let run till it kicked off and lowered jack slowly and front end of truck followed jack down as fast as I released jack.
Jacked the front back up, looked around under it and chased air lines, could not see anything. Cannot hear any air leaks, sprayed soapy water around and can’t find any obvious air bubbles anywhere.
Is the compressor going bad and just too weak to build enough pressure to lift or hold front?
What can I do to troubleshoot / diagnose?
Thank you for any info,
