Stickers I ordered off E bay
perfect fit.
			perfect fit.
Where did you get the stickers?
YesSo if I have a 21 limited is this plug and play just swapping out the light and mirror?
If you have a 21 ram why did you have to run the extra cable ? Thought it was already ran from the factory ?I just completed the install 2 weeks ago. Your right there is a lot of stuff in the headliner that makes it difficult to route the wire.
Here’s what I did:
- first remover the 3rd brake light
- pull the weather stripping on the passenger, rear and use a straightened coat hanger to push from the passenger side to the 3rd brake light opening. It’s tricky but take your time
- once the wire is through, tape the connector end to the wire with several wraps of electrical tape and pull through to passenger side
- continue pulling until you have just the amount of wire needed for the 3rd brake light
- touting the wire forward is much easier. I kept the wire inboard of the airbags
- routing the wire to the mirror was a similar process but push the coat hanger from the open overhead console area out to the passenger side headliner opening
- tape the connector like before and pull it through
Hope this helps! Let me know if you have more questions.
That's the camera cable I believe. The other wires are there, but not the camera cable.If you have a 21 ram why did you have to run the extra cable ? Thought it was already ran from the factory ?
It should be. But there is no guarantee.I'd like to get folks opinion. I had a friend of mine attach his OBD reader to my truck and the BCM says it's a 2021 Ram. It is a 2020 and built in August of '20 so I suspect that a 2021 BCM was installed in my truck since it was entering the new model year. Maybe they just didn't have anymore 2020 BCMs.. Wondering since it has a 2021 BCM would the digital rear view mirror just be plug and play in my truck? What's your thoughts?
We are working on it.We need to find a solution for the 19' and 20'
I think you need to run the camera cable. And it needs to be enable using AlfaODB. And you may lose auto dimming. It's all on this thread, but I'm trying to remember what I read.Ok, so in skimming through what seems to be 2 years worth of posts I am assuming my 2021 Limited is completely pre wired for the mirror and 3rd light. I do not have to run any wires? 100% plug and play? And do I lose anything? It was built this past June.
Thanks everyone.
Not yet, I need to get some data sent over to Jimmy07.some progress for the 19-20 models
Auto-dimming is a setting on the U-Connect with the digital mirror.I think you need to run the camera cable. And it needs to be enable using AlfaODB. And you may lose auto dimming. It's all on this thread, but I'm trying to remember what I read.
