Bought mine from the dealership like this. The dealership had no idea what exactly had been done to it. I had to call 4 Wheel Parts with the vin to figure it out. It’s a Pro-Comp level-lift with 35x12.50 Pro-Comp all-terrains on 20 inch LRG rims. I’d probably go with a little bit different rim if I had to do it over again but I’m very satisfied with the level. My Dad has the same truck(different color and stock) and there’s no discernible difference in ride quality.33988C08-E8A4-4C0E-9F0D-9BC78AC447AA.jpegA23C3DCB-9F5D-4462-B1D8-7219FA4D570C.jpeg
Bought mine from the dealership like this. The dealership had no idea what exactly had been done to it. I had to call 4 Wheel Parts with the vin to figure it out. It’s a Pro-Comp level-lift with 35x12.50 Pro-Comp all-terrains on 20 inch LRG rims. I’d probably go with a little bit different rim if I had to do it over again but I’m very satisfied with the level. My Dad has the same truck(different color and stock) and there’s no discernible difference in ride quality.View attachment 36181View attachment 36182
Looks great. What are your offsets?
2in RL Level with UCA’s
285/60R20 Ridge Grapplers
20x9 Pro Comp 0 offset
Before and after
Leveled with Revel links
Fuel Rebel 22x10 -13
Hankook Dynapro AT2 305/45r22
Before and after
Not sure if you have done this already elsewhere, but can you post some pictures looking down the side from front and back? Trying to see if I want a -13 to -18 offset or something around a 0 or +1.
Thank you!
285/75/18 Ridge Grapplers on Rebel take-offs. Level coming soon.. but so far no rubbing.
Do you have the ORP? Those 285/75/18 are like 34s or taller if I'm not mistaken. Is it a tight fit? Looks awesome.
I have the same tire in my Rebel with a 2 inch ready lift level, no rub at all...tire is advertised as a tiny bit over 35 inflated...what helps the fitment is it is a 11.25 width in comparison to 12.5 which many 35s are, the savings in width allows this combination to fit without modifications on this particular tire....it looks great imho.38B72BFC-660C-4128-BE5D-B926A5453E74.png
I don’t have the ORP so it’s a very tight fit. No rubbing at all though. Like JHRebel said it has to be because of the 11.25 width it’s able to clear the control arms and fenders. Tire shop told me they would fit and I was skeptical until I saw it installed for myself!
Readylift 2inch, with UCAs and 285/75/18 Nitto Ridge Grapplers...picture does no justice to how good it looks on the truck, also rides like a dream...the tires (limited time in them) so far blow away the ride of the Duratracs, going from 33’s to 35’s changes the truck in a really good way.
No level on your truck though correct? Just stock suspension. I was skeptical because of stock ride height. JHRebel has the 2inch level, so no question there. I think it's awesome to fit 35s on stock suspension.
Yup, he’s stock but Looking to get a level, must be a very tight fit, but seems like it works
You have the same rebel wheels correct? Is the offset on those same as big Horn 18s with a. +19 18x8?
Yes, not sure if the big horn wheels are the same though...I suspect they are but unfortunately I dont know for certain.
No worries, nothing a little internet search can't find. Thanks for your input. Much appreciated. Nice truck!
Correct no level yet. Plan on putting one on soon just can’t decide which level kit to go with. I was surprised I could fit that big of a tire with the current stock setup!
Seems like the Readylift 2 inch and Motofab 2.5 are the most popular
Items installed:
RC 6inch lift
KC led light bar & hood side lights
Fender flares
22 Hostile inch rims
Spray bed liner
Re-trax bed cover
Air intake
Side steps
Pulsar module
Pedal commander
Rhino Sports Bar
Carven Exhaust with blk tips
PA system
Blk out emblems
For those who have had to try to decide between a 0 or +1 offset or a -15 to -19 what made you choose the offset you have? I’m trying to determine if a -15 to -19 will be too much and end up with mud all down the side of my truck and if a 0 or +1 won’t be enough difference from the stock offset.
