Rammit
I talked to Readylift and they gave criteria on when this can be added to the Rebel or off road package truck. I don’t know how to add a link to it, but I did a detailed thread on this with pictures and dimensions.
Ok had a lengthy conversation with readylift. They said the 3.5 kit will give my truck a 3.5 in front at 4 in the back. The new control arms will correct the cv joint I can live with a .5 rake as long as i can have my 35x20sThat is correct, but the Rebel already has a one inch lift, giving you a total of 4.5 inches over a stock truck.
He told me as long as the front (measured from center of wheel to the fender straight up) doesnt exceed 22 in the kit will fit fine. Mine measured 22 in front and 24 in backI talked to Readylift and they gave criteria on when this can be added to the Rebel or off road package truck. I don’t know how to add a link to it, but I did a detailed thread on this with pictures and dimensions.
That’s good. Mine actually measures a little over 23”. As a result, I didn’t use the pre load spacer.He told me as long as the front (measured from center of wheel to the fender straight up) doesnt exceed 22 in the kit will fit fine. Mine measured 22 in front and 24 in back
Thats exactly what he said. Anything over 22 they dont use the spacerThat’s good. Mine actually measures a little over 23”. As a result, I didn’t use the pre load spacer.
I dont have anything in my area. I will probably use 4wheel parts. They will install readylift productsThat’s good news, do you have a shop in mind that will do this ?
That would be 4-4.5 inches of lift without a differential drop. I would be hesitant.Hello, I also have that kit installed and saw another member who had his installed and the shop also installed a Rough Country 2.5” level up front. If I remember correctly he said that the shop does this with all of their Mopar lifts.
Now of course I have no official stats to indicate whether this will over time adversely affect anything. Keep us posted if you do choose this route please.![]()
With the 2inch Mopar lift is there still a factory rake in the front. If there is a rake still could you not install the real coil spacers so the truck sits level.Posted a new Video on installation and checking all of the Mopar 2" lift kit on a dark grey 2019 Ram 1500 Big Horn. Sits on Fuel wheels, 35x11.5 Nitto Ridgegrapplers. Lemme know what you guys think of the truck and what could make it better/more appealing. Were gonna add the mopar static running boards as well.
That may work well. Definitely do the upper control arms though. You may want to verify with Readylift tech support or other good tech department to verify you can stack these. I have the preload spacer for Sale that I didn’t use. Not sure if that would work in that application though.My Laramie with the 2" Mopar Lift only measures 22-3/4". Think I will add the Top hat spacer and probably the UCA
Do I need to worry about the shift points on my 19 Bighorn if I go from stock to 35's? I read somewhere that someone mentioned that they had an issue with the truck shifting in and out of 7th and 8th gear....I guess I could always hit the gear limiter!I wish I’d have taken a picture of the truck on the standard wheels but the standard wheels and tires sit about 3 1/2 inches or more shorter than the 35x11.50’s. So from that and the end result in the video I guess you could be the judge.
Do you have 3.21 or 3.92 gears. 3.92 gears won't have any problem. If you have the 3.21s then you may have trouble between 7 and 8. Some people say they do, some say they don't.Do I need to worry about the shift points on my 19 Bighorn if I go from stock to 35's? I read somewhere that someone mentioned that they had an issue with the truck shifting in and out of 7th and 8th gear....I guess I could always hit the gear limiter!
I don’t remember what I got but I think it was be the standard ratio...thanksDo you have 3.21 or 3.92 gears. 3.92 gears won't have any problem. If you have the 3.21s then you may have trouble between 7 and 8. Some people say they do, some say they don't.
By standard I mean what would typically come on a truckI don’t remember what I got but I think it was be the standard ratio...thanks
