Trooper4
- Feb 14, 2019
- Location
- KITTITAS, Washington
If it comes from the factory with that rating as it is AS DESIGNED. What you were referring to is if a person changes shocks does it change the weight rating, and it does not. It only changes handling and the comfort one feels while towing. In essence, it only changes your weight rating, not the trucks.Again; if it reduces tow handling, it reduces payload for the same reason. Obviously your axle weight rating doesn't change. But if your truck starts walllowing like a pig with a bit of a load due to suspension changes, well you have to make sure you tow less and carry less. That's why the power wagon (and other off road focused trucks) cannot tow/haul as much as a regular 2500 even though the frame and axles haven't changed.
So in reverse, if I install a Hellwig, stiffer sidewall tires, etc. etc., then my Ram can tow 12000# with a tongue weight of 2000#. Bad, unreasonable, and errant thinking from what all the towing discussions I have read on thin forum indicate. Different side of the same coin.
