Try it...you can easily switch back if it starts "beating you up".Felt the difference on the first drive or two - now it feels back to the old ride - maybe I should go to the firmest setting? Suggestions?
Probably want to flip it to point down. Check out page six of this thread. Some photos posted on the pointing direction topic.Can someone post a photo of theirs installed?
Installed it on my 2019 Limited and the U seems to be pointing upwards.. while the stock on a neighbors big horn is pointing down.
7709 or 7883
which part number is correct
If you're lifted more than two inches, then yes.I am assuming this will work on a 2020? but I have the ready lift dont I need the extensions?
7709 is the sway bar only no end links and 7883 is the sway bar plus adjustable end links for lifted trucks. Both at are the same sway bar.7709 or 7883
Thanks brother7709 is the sway bar only and 7883 is the sway plus adjustable end links for lifted trucks. Both at are the same sway bar.
Take it around some significant corners at higher speeds. There's where I feel it the most. Coming down into the valley where I live there's a good sweeping turn at about a 30 degree downgrade. I didn't like taking it at much more than 40-45mph because of lean/roll. I took it at 55mph the other day and felt planted the whole way through.I just installed mine in the driveway yesterday, been waiting a few months for weather to turn nice.
I can't notice much/any difference. Am I just useless? It's in the middle hole, and I have a pretty light bighorn. I might try the stiffest setting.
It's well worth the money.Welp, this thread made me spend a bit more money. Mine arrives in 3 days. The wobble/sway of this truck was one of the things I never liked. 1st time im doing a sway bar on any of my 3 RAMs.
