2" Rough Country Level
When you installed 1 1/2 rear spacer did you change rear shocks or have to relocate rear track bar?
No with the weight in the truck it only gave it about a inch. Shocks are not over extended.
Keep in mind the North package comes with a factory 1” lift due to longer springs. The RC quick lift struts will only give you an additional inch as a result.
So is it fair to say then that if you have the ORP springs/struts and swap to the 3.5” RC N3 lifted struts, then you’d gain only 2.5”? I have a Built to Serve which has the 1” ORP lift. I’m looking for 2”-2.5” of lift and if this is the case, it might be perfect for my needs. Thanks
Correct. The 3.5" struts would offer you ~2.5" of lift since they would be replacing the ORP setup.
Great answer by the shop owner! Say NO to preload spacers. He said that because you’ll be back in a week blaming him for the sh!tty ride quality. That dude’s been down that road lol
Did you use the RC n3 3.5'? i have a Built to Serve too and I'm deciding if I go for the 2' RC loaded strut or 3.5'. Please let me know. thanks!
