Cup holders to small
Brent T
Laramie with full console, anyone else think the 2 cup holders on the console are to small? Nothing bigger than a regular sized cab fits in there. Wish it were adjustable or something. Maybe someone will make a different sliding tray with better cup holders ?
I have the Laramie with full console as well. Have not had an issue with the size. Seems to accommodate everything but the biggest mug style containers.
I have a yeti 26oz and there is not chance it will fit. Nothing bigger than a can of coke will fit in mine. Could they be different ?
Not sure if there are different sizes. This is with a 30 ounce or so mug. Fits great and the little side fingers do a nice job of securing it.
That cup had a small bottom though. Should be able to fit a bigger bottle/cup than this.
Good thing is, it’s my only complaint so far.
Agreed with this! My son's 40oz Takeya mug won't fit. It's not that big a deal but I think for next year's model, they should enlarge it by a little bit more..
No, you can make them adjustable or have a removable liner. Lots of them out there.
Don't know if this is the best place to post this but does anyone know why the front doors on the Limited have the foam inserts for insulation in the cup holders and the rear doors don't? Kind of odd unless I'm missing something.
I know it's an upgrade on the Laramie Level 1 package, it's just an extra set of cup holders added to the door instead of the empty pocket.
Just came across this. I agree with the OP. In the attached picture the Yeti’s on the left fit and the ones on the right don’t. Just kind of annoying. 26430The cup holders are too small. They should have some sort of adjustable mechanism. While I can fit my large Yeti in the cup holder, my low ball does not fit due to it not having a tapered bottom. It does fit in my wife’s VW Atlas because the cup holders were designed with an adjustable holder.
Just came across this. I agree with the OP. In the attached picture the Yeti’s on the left fit and the ones on the right don’t. Just kind of annoying. View attachment 26430The cup holders are too small. They should have some sort of adjustable mechanism. While I can fit my large Yeti in the cup holder, my low ball does not fit due to it not having a tapered bottom. It does fit in my wife’s VW Atlas because the cup holders were designed with an adjustable holder.
Not annoying if you buy a beverage container that fits the space designed. The two containers on the right are not what the majority of consumers use in their cup holders. Find some other first world issue to whine about
I think they are fine. The cup holders in my tundra were too big. If you had a single use water bottle in there you could guarantee it would be on the floor after the first turn.
Will the yeti 12oz hot shot mug fit ??
my 14 oz mug did not lol
We should be thankful, there was a point in time not all that long ago where cars didn't have any cup holders. Try bouncing around in a 1990 Cummins 5 speed while holding a beverage between your legs
