Whiskey_tango
- Jan 6, 2019
Wait, is the dust cover plastic or metal? (dumb question from a guy who hasn't received his truck yet or he'd know).
Okay, that's what I thought, so my second (maybe) dumb question is how in the world could it rub that paint off and cause grooves? Are you sure it wasn't always there, and is just coincidentally in-line with where that boot is? Could it have been caused during install of the kit?It's actually really soft plastic, almost rubberlike.
That makes more sense, but I still wonder how it (a very flexible rubber) could be producing that amount of down-force on the grit and grime to cause grooves in the metal, but I could be completely wrong. How long has the top-hat been installed? Perhaps you can watch it and see if it gets worse, which would tell you it wasn't a point-in-time event, but is indeed happening while driving.My guess is it's trapping grit between itself and the strut body since it's no longer concentric to the strut and instead wedged up against it.
Is an option to remove the assembly and compress the spring and reorient the top strut mount a bit in order for it to be level and/or so that the top-hat spacer is oriented correctly without 180 degree rotation? What is causing the 1" taller ORP Strut assembly to have an angled top strut mount?
Interested in this thread because I plan to put a 2" spacer on top of an ORP strut assembly.
So I checked your spring number against mine. I do not have the ORP. And my spring has a different part number. I have yet to see anyone verify the difference between the struts on the ORP to determine exactly how the 1 " lift is obtained as there are multiple ways to do it. By chance could you snap a picture of the strut part number itself? i'm wondering if they use the same strut and just put a higher spring rate coil so that the truck rides higher in its travel and the uncompressed strut length stays the same.Pic of spring tag for rsonedecker
Here's the strut tag. Looks like different P/N.So I checked your spring number against mine. I do not have the ORP. And my spring has a different part number. I have yet to see anyone verify the difference between the struts on the ORP to determine exactly how the 1 " lift is obtained as there are multiple ways to do it. By chance could you snap a picture of the strut part number itself? i'm wondering if they use the same strut and just put a higher spring rate coil so that the truck rides higher in its travel and the uncompressed strut length stays the same.
Yup different spring and different strut, I did look at mine and the plastic boot is pretty close to the strut body on the inside of each strut on both sides, I'm going to try to get underneath it tomorrow and see if it's wearing the strut like on yours. If it is I'll probably just cut it off with a razor blade. I'm just waiting on decent replacement struts from Billstein or Falcon to be released.Here's the strut tag. Looks like different P/N.
I have another post floating around here, but I verified that the ORP struts are 1” longer at rest (the piston Rod, not the body), and the springs are different part numbers as well. In fact, I have verified that the REAR springs AND shocks both are longer as well (not just the spring). I believe the lift, both front and rear, is achieved through springs, with the shocks and struts extended as well to support the proper travel.
Edit: Here's my numbers I've gathered so far (I actually have a set of ORP struts and shocks)
Off Road:
Front Spring - 68320249AB
Front Shock/Strut - 68277314AC
Rear Spring - 68262686AB
Rear Shock - 68262592AC
Stock:
Front Spring: 68320236AB
Front Shock/strut: 68277312AC
Rear Spring: 68262675AB
Rear Shock: 68262590AC
