Whiskey_tango
- Jan 6, 2019
This is exactly what I believe to be true as well. I swapped the MF for Daystar for that reason. Daystar extends the studs rather than offsetting.I noticed this rubbing on my struts with the paint being worn off so I checked around. Everyone I know who has had the lift or level accomplished by adding a top hat spacer has this rub. The way it was explained to me is, It seems to be because the EOM strut top has a designed angle built in to keep a solid contact surface with the strut housing. When you rotate the strut to allow for the new bolt alignments from most strut spacers the angle is reversed thus creating a bind. This shows up on the boot rubbing the strut and the fact that even though the bolts receive the proper torque, the spacer does not produce equal pressure on the strut housing. This is why some of the cheaper lifts and levels crack even before, or soon after the truck is taken off the lift.
Again, I am no expert. This is how it was explained to me. It is also why I had the top hat spacer removed am and waiting patiently for Bilstein to release their RHA 5100 strut replacement in September or October.
I would have liked to do struts, but couldn't wait. Maybe down the road.
