Whiskey_tango
- Jan 6, 2019
For a small lift, I don't think this is anything to worry about and probably happens in most lifts where you don't relocate the lower control arm. Since the shock is attached to only the middle of the top plate, there's room for the angles to be a little off. But definitely something to dissuade you from too much lift. When I put my stuff together, I plan to trim the boot a bit and smooth the end out - there's a good 2" that the boot extends over the shock body so there's some room to remove material. Also, I think if you slit the boot on both sides maybe 1" up from the bottom or so, that might relieve enough pressure to stop the wear (but might cause the boot to eventually crack).
I don't think they'd want to make angled top-hats because just imagine if someone put it in backwards.
I'm convinced that's exactly what they did. The stock strut can only go one way. The spacer rotates the strut 180.
So, say there is a 5 degree inward angle on the top-hat. Rotate that strut 180 and now you are 10 degrees off from where you started ( -5 to +5).
