Lablvr2
- Dec 4, 2018
I apologize ahead of time for the slightly long post.
By posting this I hope in some way to help some of the folks who are frustrated with the mystery water leaks on these new 5th generation Rams. Recently I discovered my driver side footwell carpet was slightly damp. I finally had some spare time a few days later to investigate further. I pulled the driver side sill plate up and then pulled the carpet back only to discover a small puddle of accumulated water and damp underpad. I did not want to take my truck to the dealer only to have them take panels apart and risk damaging something or not put in the effort to determine where the leak was coming from so I decided to track the leak down myself. I will preface this by saying that I am mechanically inclined and no stranger to working on or taking apart my own vehicles however running down these leaks are not that difficult and with patience and the right tools can be done pretty easy.
I, like many on this forum searched and have read all the threads pertaining to these mystery leaks and looked at the various things that could be causing them such as incorrectly installed sunroof drains or body seams that are missing sealant. My truck actually has a September production date and by then I'm guessing the quality checks were much better. I found that all the sunroof drains were installed correctly and after pulling out the driver side fender lining and inspecting the body seams including performing my own leak test I did not find those were the issue. I decided to leave the carpet pulled up on the driver side and the sill trim panel off and by chance that evening we had a storm blow through. The next morning I went to inspect and sure enough the puddle of water was back but I discovered something very interesting. After carefuI inspection I found moisture underneath the wire harness channel that the sill plate panels snap into.
It is important to know I always back my truck in my driveway and have a slight decline. I proceeded to pull the rear sill plate panel and B pillar trim panels off and also removed the left rear seat assembly and the C pillar panels as seen in the attached pictures. I could clearly see that water was under the passenger rear wire harness channel also. My rear carpet was not wet at all but I did notice there was slight dampness underneath where the rear etorque battery is mounted to the rear of the cab. I decided to spray water on the outside of the cab around the rear window and around the rear driver side sunroof drain. Sure enough and with the drain seated in the rear of the cab properly there was a steady stream of water as seen in the pic making its way down through the lowest points of the body pan underneath the wire channel and all the way down to the front footwell. I was elated and frustrated all at the same time because I could not understand why if the grommet was installed correctly it was still allowing water to pass by. I concluded that the grommet was probably actually slightly smaller than the hole in the rear of the cab and somehow was not sealing properly so to rectify I pulled it out and placed a bead of clear silicone around it and inserted it back into the cab. After leak testing again the water leak was gone.
I feel fortunate that I was able to catch this sooner than later. I know this may not be the exact fix for everyone experiencing wet carpet issues but it's certainly a place to start and easy enough for anyone to check themselves before they waste valuable time taking their vehicle in and having it sit at a dealer for days on end. If you don't feel comfortable pulling panels off and removing seats then at least this might give you some information and a starting point to pass on to a dealer so they can investigate. Hope everyone finds this helpful.
