Uconnect not loading properly
If your Home Screen has two pages, indicated by the two dots at the bottom of the screen, try swiping to the first/second page. I did this last night and it brought me to my sub menus for climate, seat and steering wheel controls as well as my BT phone menu as well as restoring the Home, CarPlay, etc menu icons at the bottom. Maybe a fluke as I tried when I returned home from work (a 2 hour drive with the bouncy screen but working CarPlay) so I wasn’t too fired up to mess around with it. Also tried the soft reset while driving repeatedly “just to see if it would work” lol. Haven’t tried it again today so I don’t know if this is a valid temporary fix until the Q1 2036 update is released.
I’ve been suffering from this menu bar issue all day today since I first got into my truck. Several start cycles later and it was still happening. So I started pressing button combos.
I found that holding the A/C and Auto buttons for several seconds brought the menu back instantly.
in an attempt to repeat it, I pressed volume and tune until the radio restarted and it came back up normally.
I’ve noted that when the menu problem is going to happen, the radio boot time is much longer than when it loads normally. This suggests to me that something is failing on initialization. It tries until it times out and then finally gives up and loads without the menu. And this is further supported by the behavior of the screen jumping back and forth to make space for the menu and then going back full screen. Something in the menu app is failing to load and it crashes and tries to restart over and over.
I’m just guessing heee but I wonder if the a/c and auto combination reboots the hvac module just like the vol and tune combo reboots the radio. Since the main top menu bar relies heavily on info from the hvac system, perhaps the root of the problem is a failure of the hvac module reporting back to the radio. Or maybe since this problem started with a Uconnect update, maybe the problem is the radio’s interpretation of the response from the hvac module. Just adding some data points and educated guesses to the conversation.
I appreciate the post, this helps me keep my sanity as I spend allot of time in my truck. The two resets you mention get the display back to normal. Thanks
Hi there, the existing firmware-over-the-air (FOTA) updates that had previously been paused last year are the current updates that are restarting and launching back out to customers. The new FOTAs and AOTAs (app-over-the-air) are still moving through the validation processes, which as you might expect from the experience that caused the graphics (and other) issues requires enhanced scrutiny before launching to all of you.
Unfortunately we aren't able to provide definitive timing on this because when packages are in testing and validation it can change at any time for any reason. As we learn more, we will share it. We're sorry we don't have better timing to share yet.
Diamond
Ram Cares
Just wanted to follow up again.
I had the menu bar anomaly again today and I was able to replicate it a few times. Pressing the AC button for about 3 seconds after the radio is fully booted seems to fix it every time.
Diamond
Ram Cares
@RamCares is there an update for the timing on release of the new software update that will fix the issues that we have all been experiencing?
My screen continues to glitch with menu items not appearing or jumping up and down on the screen as well as extremely slow boot ups. Everything worked flawlessly before the last update. Why can’t we get our trucks rolled back to the previous software version until a permanent fix is released?
Having our trucks disabled like this for ~the last year is unacceptable.
Agreed. @RamCares
The past few weeks mine seems to have gotten much worse. About 50% of the time it glitches and when it does work after a while sometimes get the loud buzz too. It’s infuriating.
Hi there, we unfortunately do not have any updates to provide at the moment. We will continue to keep the forum updated as we receive more insight.
Diamond
Ram Cares
Well for whatever reason, over the last two weeks, my infotainment center has been working perfectly. Before that, it was glitching multiple times per week. No pattern to it at all.
Someone mentioned to press the Auto button if the screen starts jumping and it stopped the jumping each time.
Anyone else just stop having problems?
Mine has been stable for several months. It hasn’t not rebooted itself and no screen buttons jumping up and down. No change in version or new over the air updates, so far this year.
Now that I said this, it will start again.
Yeah that’s how it works lol
I came here curious to see if anyone else has been having this issue, because I’ve been dealing with it for about 8 months and have had it at the dealer 4-5 times during that time span. The dealers assured me it was the screen and not software so I’m on screen #3 so far and out of pocket $1600.
I’m glad to see at least I have company in my misery and I hope we get this update soon. Until then, I’ll just have to try and enjoy the freezes and what my kids call the “robot song” of the audio buzzing.
