Any news yet on power fold for Tow Mirrors?
I beleive you also need to be sure to enable the configuration in the setting menu to appear for them to work. That adds a setting to toggle if they come on with the cargo lights.
What year is yours? I have a 23 and can't find those options in Alfaobd
2024.
I'll screen shot the menu this weekend for ya.
What setting are not finding?
That one took me a few attempts to figure out too. Like I said, I’ll post some more specifics tomorrow or Saturday.
Should hopefully clear it up for you.
Thanks, I appreciate it.
This is the main setting to flip to enable the reverse guidance lights.
Once you flip this setting to "Yes", then you will need to enable the menu option.
To find this setting, it is easiest to search for "Rear Cargo Guidance Lights Enable/Disable CSM Present" and set it to "Enable."
After you flip the setting for the menu, you will need to shut off the key, open the door, and let the truck completely power down (wait till the dash goes completely dark.
I wait about 3-5 min. Then, when you restart your truck, the reverse lights should come on with the cargo lights. When you go to your settings > lights, you should see a new menu option at the bottom to turn off the reverse guidance lights from coming on with the cargo lights.
Let me know how it goes. Happy to help if you still have no joy!
Wanted to clarify when you open the door, you need to shut it and then wait for everything to power down.
Ill have to look again. The last time I couldn't find that option in alfaobd. I wonder if this is something that's on the 2024+ models.
I believe that you have to be in the advanced menu to find it.
On the start screen, there is a button that says advanced. Click it, then go to the normal screen to edit settings.
I dont see that on mine. Im using the android tablet version. What body computer control unit are you connecting to? It seems every one i try i dont have that option listed.
I am using the desktop version. I think I remember reading you have to use the desktop version of Alpha OBD to access the advanced menu options.
Great. That figures. Can you use that on the same license? I think it remember seeing the alfa obd license is device specific.
I don't recall, but you can always email them. Can you post a picture of of your connect screen just to confirm.
For android, you go into settings and check the box for “do not verify ECU”. Then choose MY2023 for the body computer.
what are did you connect to from the first screen? bcm?
