He's talking about the truck version which is only 410 hp and in a much heavier vehicle.Say what? 485 hp is a dog these days?
Yessir. Plus with the terrible gas mileage...makes more sense to just go diesel.He's talking about the truck version which is only 410 hp and in a much heavier vehicle.
Lol, I have a buddy who's like that...he has a 2017 Rebel and I have no doubt that he would say something similar if I showed up with a Hurricane. But of course I wouldn't mind having one.A friend of mine drives a loaded 1500 Laramie with a Hemi. We caught up last night and he was looking over my Rebel with the Hurricane. Forget about HP, Torque or anything else. He cut straight to the point with the most devastating insult. My truck sound like American V8 Muscle, yours sounds like a sewing machine on steroids.![]()
All Ram trucks (1500, 2500/3500) gas or diesel other than the RHO I believe.I heard they are doing a 10 year 100K warranty on the 2026. Not sure if that's only for the Hurricane, but if so, that would be a good reason to go with it.
Does the 2026 Hemi still have Etorque?
Yes, the 2026 Hemi is only available with etorque. There is no option for the Hemi without it.Does the 2026 Hemi still have Etorque?
I’m not seeing where Ram is excluding the RHO from the 10yr/100k power train warranty. Can you share where you read that it’s excluded? It has the same engine as the upper trim level models.All Ram trucks (1500, 2500/3500) gas or diesel other than the RHO I believe.
I stand corrected with the RHO. Some reason I’ve thought it was excluded due to possible nature of hard offroad usage with tranny and axles portion.I’m not seeing where Ram is excluding the RHO from the 10yr/100k power train warranty. Can you share where you read that it’s excluded? It has the same engine as the upper trim level models.
Thanks for the follow-up.I stand corrected with the RHO. Some reason I’ve thought it was excluded due to possible nature of hard offroad usage with tranny and axles portion.
I can bet no one has seen this issue! 2026 Ram 1500 Hemi. 6340miles. Yes thats a piece of the broken valve cover, spring retainer/washer, and the top of a broken valve. Not under throttle when it happen... exiting the interstate and pretty sure it was going into eco/cylinder mode when it did it. Foot was off the throttle. Being towed to the dealer and getting a loaner.
If say that was a one off fluke where the valve retainers werent properly installed. Valve dropped, piston slammed it through the valve cover.Posted on FB Ram Group today
nothing 100%, HEMI still having issues
6th Gen Ram 1500's (2024+) | I can bet no one has seen this issue | Facebook
I can bet no one has seen this issue! 2026 Ram 1500 Hemi. 6340miles. Yes thats a piece of the broken valve cover, spring retainer/washer, and the top of a broken valve. Not under throttle when it...www.facebook.com
Yeah, so like I said, probably a one off freak issue. If the valve itself broke then probably a manufacturing defect.Valve tip broke clean across where the locks attach holding the retainer in place. Looks like a valve stem failure to me
