HOW TO: Add 360 Surround View Camera System
I was wondering if anyone here has installed 360 surround sound with these mirrors , which have the camera at an angle. What cvpm do I need to be able to do 360 in a 2019 Ram Limited?
Currently I have towing mirrors and I would like to keep the same towing mirror style, but I want to do 360 and I want to use the same ones but with the integrated camera.
Enviado desde mi iPhone utilizando Tapatalk
i’ve been reading and searching and reading and searching.
Is there a solution to the plastic camera mount in the mirrors when you drill them yourself? I aint paying 300 bucks for a piece of plastic.
Maybe an stl file?
Maybe an stl file?
No, someone had commissioned to have it 3D scanned. But nothing ever came out of it. This spring, I was going to try to do it myself. If I can, I will offer the STL for free and also printed versions of someone wants to buy it from me.
It i could get my hands on one of the brackets I could work on designing and printing them too.
I just purchased used mirrors to complete my install, but here is the part # , 68460977AA
Expensive, but if you really want to do this mod…purchase this part, or do like I did. I found used mirrors online that didn’t work, removed the brackets from them and installed them in my good mirrors. A little bit more of a hassle, but it’s pretty easy.
what's the approximate cost of parts (new) if one were to do this mod to their 2025+ 1500??
Unknown right now. Adding this on a 2025+ will be very different than adding it to a 2019-2024. I kind of have it on the back burner to figure out, but there are harness connectors that are involved that aren’t common or available to buy, so adding the missing wiring and camera cables is going to be a big hurdle. Then there’s the difficulty and higher expense of using alfaobd to do the programming on the 2025+.
