My Maxtrac lowering installation
Maxtrac is having a Black Friday deal. My tires are starting to show some inner wear. So I grabbed the UCAs and will lower the front another .5in
On a side note... I just purchased the Bilstein 24-185684 for my truck. They are about 2" shorter than the Maxtrac shocks! I had to put them on anyway because I cut the Maxtrac's off and only have one vehicle. My truck doesn't go offroading so I'm hoping the shocks don't get overextended.
Yes, the ride greatly improves with the Bilstein shocks.
Did you put on the control arms are lower it another 1/2”?
Here are some pics with the 1.25in spacers and vossens. Still no rub with the liner tip tied back. These wheels have pretty large cutouts in them. You could get away with .75in spacers and stock studs
You've inspired me! Im ordering this kit soon and im trying to get the wheels dialed in as well. I saw where you said you had a +20 offset. So with the spacer its essentially a 22x9.5 with around 11 offset right? The wheels im looking into are 22x9.5 with a +10 offset. I want them as flush as possible with the factory flares.
Yep that should work out perfectly
@ferraiolo1 Hey, I'm new to the forum. About to order a '26 Expess 3.0 TT RWD CC 6'4" box. Read your posts and watched the vids. @Rock Crawler went with a 2/4 drop but I'm considering going lower 3/5. No front axles to worry about. Have you had any experience with IHC? Saw Maxtrack 2/4 drop kit but couldn't find 3/5 from this manufacturer. Please share your opinion. Thanks
