But.... Does anyone know wich battery can be used for the services? I'm referring to the small battery. Many Thank's.
@TheWaterman83 , Tomorrow I'll take measurements to (eventually) install this one (see photo) 95Ah and 850A
Or this other:
H7 is whats in my 25, H8 will not fit. The battery you listed above is simlar in size to the H7 and should work
The EK820's dimensions match those of an H7 (BCI Group 94R)
News abaut smal battery on the 2025 ? Dimensions, capacity, model ...
Inviato dal mio SM-F766B utilizzando Tapatalk
7 years since I posted! Still loving my 2019 RAM 1500 Limited. Now has 30,200 miles on it (mostly work from home)! Heading to California next week so decided to get new tires today --- Michelin Defender LTX MS/2 275/55R20.
12V 14Ah AGM battery with a group size of AUX14.
Its dimensions are approximately 5.93 x 3.50 x 5.68 inches, and it has a Cold Cranking Amps (CCA) rating of around 200 CCA
