2020 ram 1500 limited
Elchief65
Anybody that replaced a dash due to the leather shrinking have used the old dash and were able to pull the skin off to see what is under it . Like dash pad .
I removed the cluster pad and see they have a blue glued on pad and there is almost no glue on it .
I bought a ram 1500 with 46k and it did come with the 7year / 100k certified pre own warranty. Does the warranty cover this dash problem?
The ram dealer got me saying it was a cheap 100 dollar fix but turns out it's a big job .
Any luck or ideas to get this fixed @RamCares. Please help
It's not likely that your extended warranty will cover this. Most of them do not cover soft interior items. But you can read through your paperwork to verify that. Everything that is covered is spelled out in the fine print.
It's not surprising to me that the selling dealership told you it would be a cheap fix. They probably had no idea and didn't want to do anything to spoil the sale. Ram dealership's fix is to replace the dash. If it happens while still covered by the original factory warranty it is a covered item. If it happens to our 2020 Limited I plan to take the truck to an upholstery shop and see what they would charge to recover the dash in something more durable.
I was hoping someone that had a dash already removed could remove the leather to expose the underside and to see how it looks . I went to a couple different upholstery shops and they were not as interested cause the airbag being in the dash and I know it can be deactivated but it's hard to tell what is all behind the leather just above the glove box
Hi there, we're sorry to hear of this. We recommend contacting your extended warranty directly regarding coverage. If you are still in need of assistance, our private messages are open for support.
Diamond
Ram Cares
Diamond
Ram Cares
My warranty is supposed to be a factory warranty from ram I was told . I will double check
Like I suggested, read through your extended warranty contract. There are many different warranty plans offered by Ram. So @RamCares can't tell you whether or not it's covered under your specific contract without knowing exactly which one you purchased. The only warranty we know would cover this issue is the original factory warranty, which would be expired by now for a 2020 model.
My 2019 Limited has started bubbling up on the passenger side and, like you, I also bought the lifetime extended warranty BUT it IS NOT covered. Dealer quoted me $2,100 to replace.
Hi there, did your dealer discuss possible cost assistance options with you? Feel free to send our team a private message to discuss further.
Diamond
Ram Cares
