Way to ruin Ram Limited Experience with bubbling dashboard!
I am having the same problem with my 2020 Limited. I only have 29K miles on it, and the back window is leaking and the dash is bubbling. I have already had to have the Etorque battery replaced. It feels like I have a lemon on my hands. I'd love recommendations on a dealership in the Atlanta area that can help me. Running into a road block at my current dealership.
I had my dash replaced at Palmer in Roswell. Gwinnett service department is supposed to be good. That’s where I just got my truck back from recently for my etorque replacement
This isnt due to cleaning agents, exposure to sun, lack of a dashmat or any of that... its due to moisture or rather humidity inside your cab. Probably the leaky back window or brakelight. This is a common problem with the DT's.
My dash was replaced back in 21. My back window had the typical crack in the plastic frame and was on a waiting list to have it repaired but due to Covid the windows were on back order but the dash wasnt. So the dealer replaced the dash. Of course it took way more than a year to get the window replaced under warranty and in that time the humidity was slowly ruining the new dash. Plus the dealer never bothered to leak test anything, just going off the "crack" so they never bothered checking the brakelight, antenna or even the sunroof for possible leaks. Mopar did extend my warranty on both the back window and the brakelight like they did many, if not all DT owners. That means they know this is almost a recall issue or should be.
So fast forward to now. My truck is back in service because its still leaking. The RF module has moisture in it according to the tech which is causing(and has since new) the tire pressure sensor readings to not work randomly and occasional remote issues. This can only happen from a leak in the upper roof area. So back to the circle of trying to get the dash replaced again along with warranty regarding back window and brakelight again. The dealer throws out that goodwill option pretty effortlessly which we know its because there is a cost to the customer involved. But really it should still be covered under warranty since they were unable to provide the neccessary services when it was under warranty.
This is pathetic for us that pay 70k plus for a nice truck and the dashes get ruined by a design flaw over and over again.
I have determined that the real problem is cab flex. I have noticed since it was new that when I pull out of my very angled and somewhat steep driveway that I hear cab pops coming from behind me somewhere in the rear seat area. With the larger doors, sunroof and increased length of the DT cab vs the classic body, it makes sense that its easier to twist. This of course will affect the cheap plastic frame used to hold the rear glass/slider in. The mega-cabs didnt have this problem because it had a much more robust c pillar since it had regular sized rear doors and no giant sunroof which help with rigidity.
So I wait to see where this goes this time.
This isn't a moisture or humidity issue, it's an issue with the adhesive, the amount used and leather protectants used on the dash. I've never had the back window leak issue and sealed up the CHMSL the 1st week I had the truck. If it were a moisture/humidity issue, wiping the dah down with a damp cloth would apply more and humidity to the dash than a leaky window or stop light. Read some of the above comments, many didn't have an issue until they applied a protectant
I have never applied anything my dash, wet or otherwise. So how do you explain that huh? Yeh you cant. Its humidity. And it doesnt neccessarily have to leak. Many live in high humidity areas. This has happened to other vehicles I have owned over the last 40 years. And yes the adhesive failure is compounded by high humidity.
Read again, the adhesive. My first dash didn't have a of adhesive applied and I could see the adhesive lines. The replacement dash didn't have the adhesive lines which suggest to me that the adhesive was more evenly applied across the entire surface. Many people all over have had this issue and most adhesives don't have an issue with water. Heat and less than optimal amounts of adhesive and here you are.
My dash is apparently the latest part number revision. IMO, it's not the leather that the problem but the adhesive used. On this dash, I don't see glue lines where the adhesive was applied. It's all one solid mass whereas my original, I could see lines under the leather where the adhesive was applied in back and forth stripes
Do you have the new part number? I dont trust the dealers around here. I can certainly do it myself if I could get the exact replacement! I have the exact same problem with the exact same dash. Your finihsed product makes me want to have mine repaired! Thanks
Sean
Part Number: 6PB071C1AG
Supersession(s): 6PB071C1AC; 6PB071C1AD; 6PB071C1AE; 6PB071C1AF
Just picked upy truck, everything looks good.
Leather looks exactly the same as the original. I've read some comments where the leather was changed and had a different texture but this is exactly the same. Part number is different though, ends in AG so there's been a few revisions.
No squeaks and no rattles, good job(y)
Live near you and have the same problem. Who did you talk to at Huffines and how long did it take?
I wonder what the difference is between that one and the one they replaced mine with (6PB071X9AH). 🤔
Edit after using "The Google" 🤪
The main difference between Mopar part numbers 6PB071C1AG and 6PB071X9AH is the color of the instrument panel base. Both are genuine OEM base panels for the Ram 1500, but they are designed for different interior color schemes.
Comparison of the Mopar instrument panels
Feature6PB071C1AG6PB071X9AH
ColorIndigo/FrostBlack
MaterialOften associated with leather-trimmed dashboards for higher-end models like the Limited.Often associated with leather-trimmed dashboards for higher-end models like the Limited.
Supersession6PB071C1AG is the latest iteration of earlier Indigo/Frost colored parts (6PB071C1AF, 6PB071C1AD, etc.).6PB071X9AH is the latest version of the Black colored panel (superseding 6PB071X9AG, 6PB071X9AF, etc.).
Vehicle fitmentPrimarily fits 2019–2021 Ram 1500 Limited models with the corresponding Indigo/Frost interior.Fits a wider range of 2019–2024 Ram 1500 models, including the Limited trim, with the Black interior.
I just went into my local dealership and made the request for the Goodwill repair and they very quickly wrote it up and my share is gonna be right around 700, it was a 65/35 split of the total cost which was just under two grand
I’ve been into the exact same service manager about a year ago asking if there was anything that could be done and turns out the magic words are “Goodwill repair” as was mentioned in this thread multiple times so that your clue to getting it done
You must have spoken to Chuck. He didn't argue one bit with me, inputed the info and came back with the split
