Differential or Transmission Clunk
Update from my experience w/ this issue.
I had my local dealer in Athens, AL check it out after opening a case with Stellantis / RamCares.
Champion CDJR blamed the driveshaft issue on my lift kit and refused to honor my warranty, did not service it, and teamed up with their FCA Warranty rep to restrict my drivetrain warranty to where now where any issues I have, a stellantis rep has to approve any work done to it. This is after Stellantis acknowledged the issue as described above, including the temporary fix of lubricating the driveshaft splines. The lift kit has been on the truck since it was new, purchased off a lot with under 500 miles on it from a CDJR dealer in 2022.
How awesome is that? Not only is that totally incompetent, but inconvenient as well. I nearly traded my truck in on an AT4x after picking it up from the dealer. Too bad I wasn't awfully impressed with the GMC during the test drive, because I was ready to dump this truck.
I guess I will just deal with the noise for now, until I get the patience to try and lube the shaft myself or find a local shop to do it.
If anyone has any suggestions please let me know.
Yea that sucks, and is about what I've come to expect from Ram. Ram service is the worst, absolutely terrible. I am not sure if mine is making the clunk or not anymore, I've chosen to just ignore it and not let it bother me. I'll grease it up again soon, if it goes away great, if not I don't really care.
Hi there,
Our team would like to look into this further. Please private message us with your concern details and case number. Thank you and we look forward to your message.
Gia
Ram Cares
Follow up with my 19 Laramie. The issue has been there since day one. The dealer I purchased it from and the subsequent dealer I took it to both claimed to have tightened bolts and strangely enough the noise would stop only to occur again. Only recently did I realize the problem was actually happening when it rained or I had just washed it. Out of shear laziness one day I decided to try a touch less car wash. Out of nowhere after this thing had been fairly quiet, " clunk, slap" the noise was suddenly back again. I know it may sound crazy, but my truck does it only when the bottom of the truck gets wet. Snow, rain and when I was it the problem occurs. The plan is to crawl under and track down (attempt to) what's getting wet and creating the problem.
FYI, I have the single piece aluminum drive shaft that I've pulled and greased to no avail. I'll pass on my findings if I haven't trade this thing in...
Did you ever figure out what this was? Having the same issues.
2021 Ram 1500 Laramie 2wd with etorque
Among the myriad of issues this truck has, the "clunk" is one of them. I hear it when I put it in reverse. I hear it at stops and when taking off. I hear it driving 20mph through a neighborhood and lightly tapping the gas pedal.
I thought it may have been an issue with the u joints. But I had two separate mechanics check it out and they said the joints were good.
I'm glad I came across this thread. I'll have to take the time to pull drive shaft and grease the splines.
I don't want to take the truck to the dealership just for them to keep it for 2 weeks only to tell me they couldn't replicate the issue.
Any suggestions on which grease to use?
Did it help? I'm about to try this on mine next weekend.
It got rid of the larger clunk that would happen when stopping or taking off. There's still a small clunk or "donk" type noise that I'm trying to figure out.
Gotcha. Doing mine this Saturday will update as well. Any thoughts on what the smaller clunk may be?
Reminder that need to do mine to lessen or remove that stop to first gear clunk that I’ve dealt with for as long as I can remember.
Not totally sure. I'm thinking its either the transmission or something in the rear end.
When driving in traffic, when I let off the gas and let the truck cruise, it feels like the truck wants to downshift. But if I put my foot on the gas, occasionally I'll feel a slight bump and hear what I can only describe as a "donk." I can sometimes hear it when driving slow down a bumpy road, which makes me think its something in the rear end.
After cleaning the old grease off the slip yoke with brake cleaner and shop towels and applying Ford PTFE lubricant and getting it all back together I'm happy to say the clunk is gone! I really appreciate this forum and all the help it gave me. This issue has been bugging me a while. Found this forum and I finally got it done. Thanks!
This is what my clunk while driving sounds like. When your turning drive shaft back and forth is the noise coming from the rear end or up by the tranny.
Did you ever figure out what this was? Mine is making a similar noise. Normally in 3rd or 4th gear.
Mines been doing that for a while too. If I coast in 4th, let off the gas then step back on the pedal to coat again I get a clunk.
Sent from my SM-S928U1 using Tapatalk
Wonder if anyone here has had the same issue and had it fixed?
Bumping this thread to see if anyone has had this issue fixed.
Bumping this thread to see if anyone with the 1 piece driveshaft has greased the slip yoke into the transfer case and had the fix last more than a few months?
Was hoping my truck had the 2 piece shaft, as that seems to be the culprit most of the time at the splined connection point but since I have a 1 piece shaft, I realize the only place I can grease is where the drive shaft enters the transfer case and I worry about grease contamination with the oil in the transfer case.
