Headlights and Tailights RAM 1500 Limited 2025 on RAM Laramie 2025
HelvecioFilho
Hello everyone! I live in Brazil, and the only RAM 1500 sold here is the Laramie 3.0 ST trim. I bought a 2025 Night Edition. But the taillights and headlights are very weak. I took advantage of a trip to Florida and brought the Limited trim headlights and taillights for it. The taillights are installed, and all it needed was a constant positive pulse adjustment on one of the wires (I even saw this in another post from a colleague), and it worked 100%. Now, we're having trouble with the headlights. Everything worked plug and play, except for the high beams, where some colleagues here mentioned that the headlights probably receive a CAN bus pulse on the same high and low beam pin to connect, but the vehicle doesn't send the signal. To solve this, I would need to program the BCM module, but no one here has done that yet. Does anyone have any suggestions?
Not going to happen anytime soon. It's being worked on, but it takes an extra step after changes and that's not possible right now.
How did you wire the taillights? I’ve also been curious about the headlights. Does it throw any codes with it plugged in?
The taillights need a continuous positive signal to function. After I did this, they worked perfectly with no error messages on the dashboard. For the headlights, we're developing a standard 12V signal converter module and CAN network signals to activate them. The problem lies in finding the CAN code ID we need to create for it to work. Since the only version available in Brazil is the Laramie, I don't have a vehicle with the original headlights to evaluate. Since we can't find and emulate the CAN codes, we'll open the headlight and change the entire internal architecture to make the high beams work. Note: All other headlight components worked 100%; the problem is only with the high beam activation.
Do you have pictures or video on how to make the rear lights work. I have a set coming from eBay and want to make them work as soon as I get them.
