nandalora
Nandalora, I noticed Jimmy is using the Windows version. Are you using an Android phone or tablet? Maybe the problem is it only works on Windows.
I am using an Android tablet. Thanks
I tried for awhile last year, emailed them back and forth with no answers, either they don't really understand that the Android version has this issue...............or, they don't care. I guess it's hot enough in the mornings now that I won't worry about until the Fall!Update - so I emailed info@alfaOBD asking about the issue of connecting to the comfort module on the Android app and asked if they could refund me so I could buy the windows version. Alexey refunded it, but didn't say anything about this being a known issue....I wonder if anyone has had success connecting to the comfort module from an Android tablet?
So I guess I'll try downloading the windows version. Just need to find an old laptop in my house that works...
I am unable to connect to comfort via Android as well using an MX+.I did ask Alexey of this was a known issue and he said "no". If I can successfully connect with the windows version I'll let him know and suggest he fixes the Android app.
I can't get the multi-level hesr to stay on mine anymore. I had it working until I updated to newest app version of Uconnect. Now even with it selected it won't work.As expect, I had success connecting to the comfort module using the Windows version of AlfaOBD. I found the heated seat and steering wheel parameters for temperature and time. This is great for those wanting to make changes. I'm my case, I wanted to increase the steering wheel heat temp and time. You can see the before and after screenshots of the parameters.
Also, I did not have success implementing the high/low/off or high/med/low/off levels. In fact, I believe it cause my heated steering wheel to deactivate after 5 mins when I had the multi level selected. You can access that through the body module, car config change, then search "heated wheel". You will find "material" and "level" as options to change. I also didn't notice a difference changing the material from wood/leather (factory setting) to full leather.
Before (factory setting):
After: note - I had a fault of "steering wheel overtemp" and the heated wheel would turn off after 5 mins. I think this was due to the high/med/low/off being selected, but it also might have been from having different temps for high/med/low, so I made them all the same. Now its 35C for ramp and 40C for steady state.
Autofold doesn't work without using live settings of TazerDT.Btw, I tried adding automatic folding for my mirrors...didn't work.
I have power folding tow mirrors which I fold in when I park, so it would be nice if that was automatic. So I found the setting in the BCM module and enabled it. The setting even shows up in controls on the uconnect screen. But when I check the box it automatically unchecks after a few seconds
Tazer can do it. Works like a charm on mineBtw, I tried adding automatic folding for my mirrors...didn't work.
Go with the Tazer !Btw, I tried adding automatic folding for my mirrors...didn't work.
Hmm, i have 24 Limited, added Offroad/performance pages via Alfa to EVIC but didn't notice any air-suspension changes, still 5 settings, all work normal.On my 2022 Limited, I'm running links to level the air suspension, and it rides great in Normal, bouncy in OR1 and OR2 is unusable, which is fine. I used Alfa, playing with settings to see if Off Road and Performance pages worked with the latest uConnect update. I enabled VehConfig 2: Off-road capable and VehConfig 5: Off-road Pages Present. It added the Off-Road page on the EVIC (not uConnect) but also seems to have changed the air suspension setting. It seems like Normal is now OR1. Is that the expected behavior of the Off Road Group with air suspension, to adjust the air suspension up a notch? Only other changes were tire size, which on my '22 didn't require anything other than the "Program Tire Size" menu, no ABS or other changes.
I just triggered an error regarding the fcw, I think. Might have turned on the off road camera by mistake and now it is looking for something not available. Have you found if you can enable or disable fcw? I tried disabling it then enable but it didn't change my error fwiw.I made a post in the general thread about my ability to enable/disable Forward Collision Warning is no longer showing in uconnect. Can FCW be enabled/disabled via AlfaOBD?
I am finding the same thing. I put the off road package on and it looks to me that it is higher than before. I have lowered it from aero 2 to level one and it feels best there. I disable the ride set to auto aero so I can keep it at the current level. Have not tester it driving yet but if anything changes I'll update.I have a ‘22 with the Off Road Pkg. and it does ride 1” higher. I only have 4 different settings whereas my previous air ride trucks had 5. So it sounds like you are fine with your settings.
Do you still have 5 positions to choose? Curious to what happens. Maybe one just over rides another in effect you only have 4 selectable choices.
