Ramboy13
Same here. Unfortunately.I got the same issue.
Have to check the complaints and TSBs…
I've had rain sensitive wipers since '08 in multiple cars. The RAM ones are on crack.The rain sensitive wipers sound like they’re working as they should.
The intermittent setting is actually the sensitivity setting… as in… how much rain is it gonna allow before wiping.
How much rain it sees at once on the windshield depends on how much it’s raining and vehicle speed.
Respectfully, I think at least my truck is not working correctly. This is my third Ram, and I've driven countless rentals throughout my work life, and I'm fairly used to differences between vehicles. But the way the wipers work in this truck is different from anything I've experienced. Just a few days ago I drove a couple of hundred miles on interstate during intermittent rain showers. At one point, my windshield was totally soaked, and yet the wipers did not come on. I use Rain-X and usually it's not an issue for me, but my wife commented on it, so I manually turned the knob and then back. It started working normally.The rain sensitive wipers sound like they’re working as they should.
nailed it. and a hell of a lot shorter than my "war and peace" post.... (sorry all)I've had rain sensitive wipers since '08 in multiple cars. The RAM ones are on crack.
Exactly - I agree. I was trying to see how the windshield looked behind the rear view mirror. The other day I swear my window was dry. The hood didn't even have a drop on it (the ceramic coating is amazing).Maybe there is an issue. I know the new versions generally use a sensor that’s housed in the rear view mirror enclosure so, that area not being clean can cause issues![]()
Finally took two seconds to look at this. It pried up very easily and the wiring harness is very neat to a single multiplug. My problem was quickly obvious. There are supposed to be 6 clips, and one of mine is missing.True. I'll try to grow a pair and pull up a little harder on it....
Awesome! Did it fall into the door panel?Finally took two seconds to look at this. It pried up very easily and the wiring harness is very neat to a single multiplug. My problem was quickly obvious. There are supposed to be 6 clips, and one of mine is missing.
That's a good question! I looked to see if that happened. The area under the panel is pretty well self-contained, like a little tub. There's a small slot against the door panel where it *might* get through, but it'd be a trick to happen by chance. I checked everywhere I could, short of pulling the door panel off. I have a pry tool for the fasteners, but that's never a pretty job.Awesome! Did it fall into the door panel?
No, it’s not. Maybe your dealer has one laying around. If not, maybe junk yard. eBay/Amazon thereafter.That's a good question! I looked to see if that happened. The area under the panel is pretty well self-contained, like a little tub. There's a small slot against the door panel where it *might* get through, but it'd be a trick to happen by chance. I checked everywhere I could, short of pulling the door panel off. I have a pry tool for the fasteners, but that's never a pretty job.
Definitely curious to see if the proximity wake-up works.
And it’d be a hell of a coincidence if two batteries in the same truck had bad cells. Maybe buy a lottery ticket!![]()
- Can't figure out the logic behind approach lights. They seem to work once in a while.
The battery indicator is confusing. When I turn on the car, the indicator shows close to Low. When the car starts running, the indicator is close to the middle point, but never close to High. That is on a fresh truck, should not the battery read close to High all the time?
@StuartV - Did the dealer say that you could have done something to spot the problem early on? I am going to the dealership for my first oil change and want to inquire.
(Btw, nice seeing you here, friend!)
I debated on whether I should go with Line-X. Decided against it for now. The way I see it, BedRug is a reversible decision. Line-X is not.
Forgot to add... 23.5 mpg over 1000 highway miles. Smile on my face. Zero stops on the way to my destination. Taco was barely 19 mpg on a good day on the same trip.
I dunno if that’ll work. The bedrug is held in place with sticky back Velcro and the line-x won’t allow adhesion very well… just something to think about@RamTruckMan - I may do the best of both worlds and get Line-X and Bed Rug. Keeping the options open. Bakflip MX4 should keep things dry and an RC Mat will go either on top of BedRug or Line-X.
BedRug offers a solution for spay-on beds, it is an adhesive kit you'd get separately.I dunno if that’ll work. The bedrug is held in place with sticky back Velcro and the line-x won’t allow adhesion very well… just something to think about
Thank you!!!! I may get a bed rug now over my factory spray in… I didn’t know…BedRug offers a solution for spay-on beds, it is an adhesive kit you'd get separately.
2025 Ram Truck 1500 RealTruck BedRug Spray-in Adhesion Kit for BedRug Liners | RealTruck
RealTruck ships the 2025 Ram Truck 1500 RealTruck BedRug Spray-in Adhesion Kit for BedRug Liners fast and free within the lower 48 United States. Take advantage of our product experts, image galleries, and legendary customer service to get the right part with no hassle.realtruck.com
Yea, I lived in GA for a while. used to run I16 from Macon to Statesboro where I went to school and it was pretty much wide open. I almost got caught once but the highway patol got stuck doing a turn around in the median. LOL@RamTruckMan - you can't compare CT to GA. I got experience in both states.
In GA, you can open it up nicely, but I don't want to get into a habit and tempt highway patrol when I am out of state. Folks do 85-90 mph regularly, and it is super easy in a SST.
