TRX Steering Wheel Swap
So I found this code U1477, does anyone know what could be, I'm thinking is wiring but just in case someone had this problem before, maybe @Jimmy07 can give me some light on this one,
Thanks in advance..
Update:
Everything is working like it should now,
The wiring harness was bad, looks like someone had messed with it as some wires were spliced and taped together, installed a new one and problem solved, very happy with the outcome, tuned the transmission with GDE and they work as manual shifting like intended..
That is very cool. If you're able to can you take a video of it in action?
I have a 2021 rebel and very tempted to do this cause it seems very reversible if needed.
Also I assume when you pull the paddle it shifts into "manual" mode. Do you have to turn the shifter knob to neutral then back to drive to put in automatic mode again?
As soon as I get it back I'll make a video, it's been at the dealership almost a month now, it's getting all the bottom suspension bushings replaced at 20k miles they're all bad (since I got the truck new it's been shaking a bit and they couldn't find the issue) but it got really bad shaking and jumping horribly at take off and a bit at high speed, hopefully all the shaking goes away now, while doing that the beautiful technician at the dealership bang the hell out of my ReadyLift UCAs to remove them and destroy my ball joints in the process, so now waiting for new ones so they can replace them 🤦‍♂️
As to the paddles they work in manual perfect and even as gear limiter when you keep the + pressed it comes out of manual/limiter mode, try it on your rebel, it should work..
