KINGFUROOK
- Jan 28, 2025
Use in lte fall, before winter, not nowI bought some fluid film for the first time that someone recommended..
Thats some of the best waxes I've used. Its very forgiving on surfaces wax typically make a mess of and the ease of removal is great.First time hand waxing the truck. Coming from 15 years of owning white / silver vehicles I forgot how much pop you get from the darker colors. I also forgot how much work it is
View attachment 201059View attachment 201060View attachment 201061
I did as well for my spacers I'll be installing this week. I haven't tried it yet, but sounds like it may be very useful especially in the winter.I bought some fluid film for the first time that someone recommended..
Should be fixable, and airbags should never deploy if you get rear-endedGot hit from behind on Wednesday. Took in to body shop this morning. Hoping they don't total it out. Drives fine though. airbags didn't deploy but had the white powder as if one was all in cab after I got hit. Any ideas if they can end up fixing or if it would be considered otherwise?
View attachment 201068View attachment 201069
WoW! That's NOT goodGot hit from behind on Wednesday. Took in to body shop this morning. Hoping they don't total it out. Drives fine though. airbags didn't deploy but had the white powder as if one was all in cab after I got hit. Any ideas if they can end up fixing or if it would be considered otherwise?
Where is 10-E-C located?WoW! That's NOT goodI'm hoping those fluids weren't belonging from the truck.
If the trailer hitch is straight it'll be fix is my guess. There is a steel plate behind the license plate which ties the trailer hitch to the frame.
I only know this because I put a new rear bumper on the other day. If it bent the frame they may not idk...
I have an extra bumper for sale
thats a step stool that got crushed... by a vehicle lolI've not seen a ladder like that. I've used similar ones that you lay down on over the the engine, but I cant lay on my chest and breathe very long.
Is that one actually an automotive or painters design?
Being. 2019, it's possible the batteries were going bad. Not sure if you can replace just the batteries. But they aren't too expensive to replace the whole thing I guessReplaced drivers side TP senders, they failed one after another in a couple weeks time.
Waiting for the passenger side to start acting up.
They at least are consistent. Can you not replace the batteries in them?Replaced drivers side TP senders, they failed one after another in a couple weeks time.
Not sure how much of a difference it might make, but a v-nose may pull a little easier than that big sail.Today I tested out towing my buddies 27ft fully loaded enclosed car trailer to see if it was feasible for me to buy one. Between the distribution hitch and my bags it barley felt more then my normal 20ft open car trailer.
Although I think I want to switch to the 33gallon tank and swap the 3.21 gears for the 3.92 gears before I start actually shopping for an enclosed trailer to tow long distances to events.
Def I’ve got time to decide on what to buy, this was more just to see if a bigger enclosed like this was feasible I will probably end up with a 24ft anywayNot sure how much of a difference it might make, but a v-nose may pull a little easier than that big sail.
Oh man sorry this happened to ya! That’s one of my worst fears is some dumb @ss on their tele and ramming(no pun intended) into the back of me!Got hit from behind on Wednesday. Took in to body shop this morning. Hoping they don't total it out. Drives fine though. airbags didn't deploy but had the white powder as if one was all in cab after I got hit. Any ideas if they can end up fixing or if it would be considered otherwise?
Be sure you file a diminished value against the drivers insurance company. Not many folks know about this.Got hit from behind on Wednesday. Took in to body shop this morning. Hoping they don't total it out. Drives fine though. airbags didn't deploy but had the white powder as if one was all in cab after I got hit. Any ideas if they can end up fixing or if it would be considered otherwise?
