A BIG FAT NO! Save your money my friend. I suggest you buy one of these and cut out the carbon filter:Does adding a cold air intake improve mpg or hp? I seen some people say it helps and some say it does nothing.
Sorry Vinnie...I'm not allowed to talk to Mr. Canada anymore or I'll get in trouble after he reported me because he didn't like what I had to say
So true. I was on the K&N train for a while, until I saw dirt all over inside the intake and my turbo impeller looked like it was sand blasted. If you hold a K&N filter up to a light source you will see light shining though tiny holes everywhereAdding a K&N filter will definitely increase your engine's ingestion of foreign particulate. Stick with pleated paper.
THIS^^^I think RAM intake is already free-flowing compared to say Dodge Charger/Challenger where the same engine has 375 HP compared to 395 HP in the RAM. You may get 10-15 HP at the top of the RPM range but feel nothing with your butt dyno.
It is a dense material that can impact flow. I posted pics of my AEM install with the carbon filter delete. You can clearly see from the pics the thickness and density of the filter.l can see adding a free flowing air filter but, why would you need to remove the carbon filter on the lid ... is it restrictive ...
View attachment 85451View attachment 85452View attachment 85453
If you remove it and drop in the attached, you will have the equivalent of a $300 CAI with no performance differences.much appreciate the reply ... l do see what you are describing ... l will be removing mine asap ... thx
Will it make it sound louder?No , save your money.if you feel the need to do something put in hi-flow aire filter such as k&n and remove charcoal filter from air box lid.
