The RAM switch sounds “vaguely” reminiscent to what Ford did in the 2012-2015 timeframe. They had the 5.4 or 5.0 v8, then got the 3.5 twin turbo. At first it had teething problems, just like the Hurricane does. Then (eventually) they solved the main issues the motor had. Course it took an engine refresh in 2017 to fix some of their problems.
From website “Motorreviewer”:
“In 2017, Ford has revised the design of the 3.5L EcoBoost and a new more powerful version became available for the 2017 F-150, 2018 Expedition, and 2018 Navigator. The upgraded engine received a number of changes, but the most noticeable of them is the addition of multi-port fuel injection and new turbochargers. The operation of multi-port fuel injection is combined with direct injection. It covers a raised fuel output needs but also prevents a carbon buildup on the intake valves, keeping the engine on the same level of performance during a long mileage. New Borg Warner turbocharger has turbine wheel made of MAR-M-247 super alloy and electrically actuated wastegate reducing turbocharger lag even more.”
In summary, RAM will sort out the problems with the Hurricane by say 2027. Until then, earlier adopters will remain the beta testers for Stellantis/RAM. A factory extended warranty should be mandatory. It will be a good motor, just like the 3.5 turbo Ford has. Ford has their V8 purists just like RAM does, so RAM bringing back the hemi (some version of) makes sense. All IMHO of course.
