Performance Pages on 2022 Limited 12 inch UC5
I’ve done all of the changes as your write up and I get bunch of errors faults including service 4wd?
I’d there any fix so we can clear all the errors??
Thank you
Yeah, you can't apply the stuff he did you will need to revert all the drive modes and srt stuff.
What are you trying to do, and what have your done so far?
Well I’ve done all as me and I got the extra performance pages but I had fault codes so I just reverted the SRT and all fault codes disappeared along with the extra performance modes
Thank you
If your truck is 4x4 you can’t set
VehConfig 3: Vehicle is an SRT: Yes
VehConfig 3: Sport Mode Present: Yes
You have to set these ones: No
This will take care of 4x4 errors but I’m not sure what other changes you made. Do not follow this guide if you want to get the performance pages/off road pages. This guy changed settings you don’t need to mess with. Unfortunately I changed my settings to get the pages a while ago I don’t want to give the wrong info.
These are the only settings that should be changed for the pages
VehConfig 1-Performance Pages Present - Yes
VehConfig 2-Off-Road Capable - Yes
VehConfig 5-Off-Road Pages Present - Yes
anyone know of the off road pages work on a 2019 bighorn with 8.4 Uconnect 4? Non ORP
I have jscan.
Thanks
I know this whole thread is on getting rid of the tcm. Has anyone gotten a brand new tcm to work on a 21 that has a 12” uc5
I think the one plug I need is the harness plug to the tcm but also ability to where to connect it to make it work.
So once you get hit with ota update and lose performance and off road pages, is there a way to get them back? I tried toggling off and back on in Alfa and still can’t get them back on the radio, but they are in the cluster
You can get them back if you factory reset the head unit but keep in mind that in a few days if lucky they will shut them down. Normally takes about 2-3 days. I did it couple of times but got tired of setting everything up again so I have them in my cluster.
Can performance pages be equipped in uc4??
So I did this last night and they came back. This morning I checked and the dashboard page is still there but performance and off road pages gone already. I agree, not with the reset procedure to disappear that fast.
Finally joined the rebels 💪🏼 My truck and I do with my truck what I want 😂😂
Thank you all for this write up 🍻
Did mine, performance, offroad, over a month ago, 24 limited, and still there
It is a pain in the rear to take that box out. They knew what they were doing by positioning all connections facing away from access point and the bracket from hell. I did a factory reset and all is there once I set up everything again. Off road and performance pages all work as intended with all gauges reading the data.
  • Like
Reactions: jmr
I’ve reset mine and the longest they stay is 48hrs and then back to just having them in the cluster and not the radio
Is not really bad to get the box out. It took me about 1.5hrs. Getting all the panels off was super easy. Getting the box out is time consuming one bolt is nice and accessible but the other one is an issue. It will come off it just takes time. Now no more factory reset and I’m off the cloud. No more updates in the app on my phone😂
How long did it last on the screen
