Finished Build: 2021 RAM 1500 ORP Suspension, Tires & Wheels
Only if you reuse the orp coil. If you remove the orp strut and do not reuse the orp coil you would get a 3 inch lift.
Other than the rough country strut assemblies, most strut lifts are adjustable with different clip settings between the ORP and non-ORP coils. What he said is.true for the Rough Country lift strut assemblies.
ok re-write
if you use a 3' LOADED strut lift kit that is NOT specific to ORP ( or REBEL) suspension ...you will only get 2" higher than an ORP (or REBEL) lift.
This has to be beat to death by now spacers vs LOADED STRU vs non-loaded strut vs adjustable strut....preload SPRING spacers...
does this place NOT have stickies?
I recently finished the suspension lift and tire/wheel upgrade on my truck. I wanted to share the details of the process, what worked and what didn't, that might help other members make decisions with the investment of their future truck build. I gained a lot of information on this topic from other members on this site, so I felt obligated to pay it forward. In today's economy nothing is cheap, especially if you want to utilize quality, mid-grade suspension parts and totally avoid the cheapest route to take. Keep in mind during this thread that my truck is used lightly for daily city driving, highway/interstate traveling, boat and buggy towing, occasional off-road driving on Florida sand roads/trails (my Beast Buggy is used for anything more extreme). If you want to run a hard-core off-road truck, this thread is obviously not intended for you. It is important to note that my truck has the factory "Off Road Package". All suspension parts used were intended to work for ORP trucks.
My goals were:
- run 35X12.50 tires on 20X9 wheels
- keep a quality street ride (as close to factory as possible)
- keep the original front suspension crossmember and related components
- stiffen the rear suspension for better towing performance
- have no tire clearance issues withing the front fender wells
- have between a 1" rake (for towing) and a leveled truck
- be able to park the truck in a typical 7ft tall garage door
Suspension lift components:
Front suspension
- Bilstein 5100 strut shocks (2” lift)
- Motofab top hat spacers (1/2” lift)
- Rough Country upper control arms
Rear suspension
- Icon dual-rate coil springs (1” lift)
- Motofab coil spring spacers (1” lift)
- Bilstein 5100 shocks
Wheels: Fuel, Ammo 20X9 6X5.5 +1 offset
Tires: Toyo, Open Country RT Trail 35X12.50-20
Results
Did I meet all of my goals? All but one! It rides great, tows better, sits dead level and I can still park it in my garage (the cab and roof antennae barely clear by about 1 inch, but it does clear) The one goal that fell short was clearance, the one small issue that bugs about all of us with lifted 5th gen RAMs. The dreaded factory front mud flaps are evidently a curse. I have slight tire contact here when the front suspension is canted or when in reverse in a tight turn (I have yet to find a mud flap solution that will maintain a factory look without removing or cutting it) Also, the flimsy front wheel liner (toward the front of the tire, at the bottom edge near the center) made contact with the tire at full turn. This issue was solved with using a plastic push retainer (8.5mm) and zip ties. The addition of the push retainer inside the wheel well (used as anchor points for the zip ties) gives a clean appearance that looks like a factory install.
Lift Height (measured from wheel hub center to the top center of the fender well lip)
- the truck height with stock suspension sat a 22.5" front and 23.5 " rear
- the lifted truck height now sits at 25.5" front and 25.5" rear
- total lift was +3" front and +2" rear
I was surprised to see that the front end was .5" higher than anticipated. I have driven the truck almost 100 miles and it still sits the same height of 25.5". The truck sits dead level (note: The truck bed has some weight additional weight that is present 24/7. The Retrax cover, Go Rhino racks, as well as gear inside the bed. This weight compresses the coils springs roughly .5")
Conclusion
It was definitely a fun project, and I am incredibly happy with the results. Now I will focus on some smaller details such as adding step boards, removing chrome emblems and replacing them with black ones. I hope someone will find a few ideas in this thread that will help them with decisions that will work for them on their RAM ORP truck project. God bless and pray for our Country.
Did you have your wheels/tires on the stock suspension at any time?
spacers will change the ride quality SOME but only due to the change in the control arm angle. SPRING rate does BOTH rasies the truck (via the increased spring rate prevents the lower control from compressing upward as much....hence same control arm angle change) AND is also stiffer. (due to increased spring pre load) Smart is an opion. Effective is a fact. Due to the geometry of how suspensions work (swing around a pivot point creating an ARC of movement) one must not move TOO far from the arc centerline or you will suffer severe changes in both ride quality and safety/longevity of components. The ONLY effective method of raising the truck with the
spacers will change the ride quality SOME but only due to the change in the control arm angle. SPRING rate does BOTH rasies the truck (via the increased spring rate prevents the lower control from compressing upward as much....hence same control arm angle change) AND is also stiffer. (due to increased spring pre load) Smart is an opion. Effective is a fact. Due to the geometry of how suspensions work (swing around a pivot point creating an ARC of movement) one must not move TOO far from the arc centerline or you will suffer severe changes in both ride quality and safety/longevity of components. The ONLY effective method of raising the truck with the LEAST affect on ride quality would be a body lift. (not talking about autocrossing here)
I have a 2022 ram sport, had 1 1/2 tophat my truck drove like crap, changed to 5100's set on #5 and orp springs, night and day difference, also have RL uca's bilsteins in back, no spacer, level truck, 3 inch in rear 2.8 in front
Thats how its done.
ok, let me try this again, H2OMAN help me out. 2023 Rebel GT with ORP and 1" factory lift. I want to put 34" tires (KO3...285 75 R18 or 295 70 R18)...width may be a problem as the UCA has about 1" of clearance with the current stock 275 70 R18 tire and would prefer to not change UCAs.
in order to avoid rubs, was thinking of swapping out the current blue Bilsteins for 5100s, for an extra 1.5" lift added to the current 1" but maintaining some rake for heavier loads. As specific as you can be, what exactly would you do to accomplish this on the front and on the back, keeping same springs or not, which shocks specifically.
I would go 285/75 and if changing to 5100's, I would do all 4 corners because my OCD would hate me and plus this way suspension wears the same. Stick with OEM coils.
What you wrote was exactly the setup I had before my current setup. It worked just fine.
You can run a 285/75 right now with no additional changes needed, other than updating the computer for larger tires
