- Apr 11, 2019
Based on the behavior I see of the surround view kit on yours and @Laramieblue truck, and that same behavior on previous model year trucks, I know for a fact that it will work provided trailer surround view is in the bcm configuration on these 2025’s (and I’m sure it is).I doubt that it will work, based on the how the UConnect system is "programed" to work, 2 AUX cams. Result of both programing, hardware and the reuse of the video connector on the bumper from prev generations.
Once we figure out how to do programming with alfaobd on these 2025’s, once you enable trailer surround view in the BCM, your AUX 1 camera key will disappear, and all the trailer surround keys will take its place, and you will still have the AUX 2 key:
I’ll dig up the pinout tomorrow.Do you have a source to get the pin out of that 12 pin connector? Diagram of what pins do what? That may be helpful in interfacing to it.
Basically, you have 10 pins being utilized:
Power
Ground
Can BH+
Can BH-
Camera 1 signal
Camera 1 common
Camera 1 shield
Camera 2 signal
Camera 2 common
Camera 2 shield
The 6 camera circuits originate as the aux camera analog inputs on the radio module.
Power and ground is used to power the analog aux trailer cameras and the Trailer CVPM (that camera processor box).
Can BH is how the CVPM and radio communicate with button presses for different camera views.
Since your truck is configured for two aux cameras, you can actually pin 2 standard aftermarket analog cameras into the 12-pin, and view them with the aux 1 and aux 2 camera keys.
When the truck is configured for trailer surround view, you can use the surround view cameras, and you can also wire in an extra analog camera (like on the inside of the trailer), and view that with the aux 2 camera key.
