soedog
Quick Thaw / Quick Mod - From single digit temps yesterday to mid 40’s today and back down to the 20’s tomorrow so figured I would install the Mopar Window Deflectors I picked up from the dealer a couple weeks back. Always used Weathertechs in the past but really like the look and fit of these.
Simple install taking about 30 minutes to fit them, 5 minutes for the fronts and 25 for the rears due mainly to getting the small plastic rivets popped in that join the metal clips to the deflectors. Just a tip but if you are considering these it helps to have small fine tipped needle nose pliers to hold the rivets in place and a plastic trim tool to pry the rubber window seal open to insert the deflector clips.
