2025 Ram 1500 Current Owners - Discussion, Feedback, and Problems
The dealer just replaced both batteries on Monday. was running in the low to mid 14's prior to that.
Yeah, but if the batteries were new and you’ve just driven for eleventy-billion hours and now they’re where they are, for some reason, it seems like they’re not charging right. Part of your alternator works since your radio didn’t die but… Just my 2¢
Any way to turn off the 3 horn beep when you exit the truck with the fob and the truck running? I have seen posts saying you can turn it off in the settings, but I can't find it. Any help is appreciated.
Have you looked under doors and locks in vehicle settings?
I haven’t found it. One of the things I’d squash if AlphaOBD decrypts the CAN bus. What you can turn off is beep on lock and beep on remote start.
Additionally, some of the USBs stay powered after the truck is off. I recommend not having things plugged in those
The USB ports located in the center console will stay on for about 45 minutes.The idea was to continue to allow charging or have both Carplay and Andriod Auto still active so if you return with in that time frame you just start the truck and everything remains as before no need to pair or blue tooth.If nothing is connect the module will stay allowing a passenger to continue or driver to charge
I have seen some posts where guys have said it's in there somewhere, but maybe that was changed for 2025. I did turn off the honk on everything else.
It's not in there. It wasn't able to be turned off on the previous years except if you used Tazr. Alfa wasn't able to disable that feature, at least in my 2023.
I’ve only used Forscan (to do the same thing to my ‘21 Ford) and just learned of Tazr and Alfa and don’t (and may never) know which one does what.
I’m just hoping someone will either crack the encryption OR a disgruntled Stellantis employee will steal and post the key 😂
I went through all the settings on my truck and can’t find anywhere it will let me disable the horn honk on exit with the vehicle running and key outside of the truck.
I drive my truck a lot for work and am constantly getting in/out of it while it’s running. I have resorted to just letting the door slightly close instead of closing it all the way. Makes it look like it’s closed but doesn’t honk at me.
You can hold the fob against the window as the door closes, it'll think it's still in the vehicle. This worked on my 2023, I imagine it'll work on these too.
I just let it
Good tip. But, man, it’s ridiculous to need these shenanigans.
Does anyone who uses CarPlay notice that sometimes Siri’s voice, reading messages is way too quiet? Anyone figure out why? Thanks
Yup, been trying to figure this out. One would think it would be the same volume as music you are streaming but nope.
They only work on approach with Laramie and up. Otherwise it’s only when unlocked by the fob. If you don’t have touch/passive entry, the truck doesn’t look for the key
Nothing turns on on approach for my limited. I have proximity wake up on. The animation and ram log turn on when I unlock. Is there another setting? Am I missing something?
There’s an approach and an unlock setting in lights setting.
