woods87
- Jun 4, 2022
Can the small grille lights be removed from the grille?![]()
Has anyone installed it with the front camera?
Here is where I bought mine, the letters are included:Does anyone have a link to where you can still purchase this grill?
How's the quality? Happy with it?Here is where I bought mine, the letters are included:
Thanks a ton for the update! I'm really digging the look.I didn’t expect OEM quality for the price. But it is good for what it is. The fit is damn near perfect.
Be careful with the letters and mounting them to the grill. They are two pieces and the housing that mounts to the grill is not super thick plastic at the screw holes. Don’t over tighten the screws. There are four screws per letter, so it’s not likely to come off if one went missing.
I just sent a message to the ebay seller I bought from to see if they can sell just the lettersI managed to buy on of these grilles off of AmericanTrucks.com but it did not come with the letters. Has anyone found somewhere to buy the letters only and NOT the LED versions that cost a ton? I saw one seller who paints them for $400 but I'm hoping not to spend that.
looks great!! does anyone know if there is a way to wire grill lights to come on when you remote start but then once you actually start the truck or put it in gear they turn off?
I have been trying to figure out how to wire up a led strip under the hood bot only wand it to do the animation when I remote start then when I push the start button for the remote start to be taken over by the normal ignition it go out.Only thing I can think of is using a relay to turn them off if the car is in the run position. Not sure what circuit would trigger this though.
I currently have tazer DT and the amber DRL turned on and I noticed when my remote start is on the bottom marker led in the headlights are on but then when I hit the start button they go out and only the top amber drl stay on. I wish I could find out how that is toggled. I asked the tazer people and they aren't even sure
Yeah. I wish I could find some kind of tap or fuse that works only when remote started.I am sure you could tap the running light circuit. But that means they would also come on with the headlights
Interesting. the headlights aren't on tho in the day. I wonder if there are different circuits that can be found on the top and bottom marker lightsI am assuming it’s a data trigger. But you could use a relay to use the running light circuit and then a second trigger to turn them off when the headlights are on. Just have to find both circuits and do a ground relay on off
