Memory seats
I can confirm that the memory buttons will function with just parts replacement and AlfaOBD settings for the memory components you have installed. In my case (Bighorn Level 2) I did the following:
  1. Replaced the door harness with a Limited harness (this was to have ambient lighting and memory buttons, any harness with memory would work)
  2. Swapped out the seats with memory power seats from a TRX
  3. Enabled the AlfaOBD settings for seats with memory. I also enabled the mirror Memory settings but have not yet installed mirrors with memory (they are incoming)
  4. Ran the twisted pair from the Can IHS bus to the pins 17/18 on the seat connector. I used 4ft of Cat5E cabling and just used a single pair.
For the Can IHS connections I used the following parts ordered from DigiKey:
17-5-963715-1CT-ND (female pins used at both ends of the wire)
A128871-ND (connector to pin to and plug into the Can IHS bus block)
The under-seat connector requires you to pull out the plastic piece locking the pins. Then you can insert the pins into the connector and push it back in.
This resulted in working memory functions and a working set of memory buttons on the door panel. I also swapped the TRX door panels, which included the memory buttons. This is what took me down this road, because I hate having something there that doesn't function. The buttons do not light up, but I am not sure if they are supposed to.
Some additional notes:
  • I had heated seats and steering wheel from the factory. I have seen in other threads, that if you don't have these OEM optioned you may not have other wiring necessary for the swapped seats to function.
  • I had to run power to one pin for the passenger seat power functions to work.
  • In all, I had to run only these three wires for the swap.
  • I also converted to the console shifter, but that wiring is there and just needs to be repurposed from the original rotary shifter.
Any chance you can give a parts break down? I have the powered seats, mirrors and pedals but not sure if I need different seats or just the buttons, wire harness and AlfaOBD settings to accomplish this.
Thank you for your post. I am taking on a tradesman 2500 4x4 with the equipment and tow package 12 inch screen included. I was able to pick up a trx center console with shifter on marketplace. I am searching everywhere for any information on the swap as the connectors are not the same in the 2500 and 1500 to direct swap. Tracking down the correct pins without a diagram is my main problem. Any help would be greatly appreciated. Will upload my findings if ever found. Thanks.
Go here and enter your year, make and model. Then find the connector for the console and compare to 21 and up TRX:
Would you happen to know if either of these part numbers are the correct harness to use? It'll be for a 2020 big horn.
68429501aa
68488533ab
Why would anyone need memory seats? That would mean you were going to entertain the idea of someone else driving your vehicle and who cares if the passenger needs to adjust their seat, they’re lucky to be riding shotgun :ROFLMAO::ROFLMAO::ROFLMAO: j/k (kinda?)
Nothing more irritating than when my son, daughter, son-in-law and service people drive my truck and adjust my seat like they want it and saved it in memory!!! Then when I get in, my Memory is GONE!!! Then Memory 2 is my wife!! So I put her in memory 1 and me in 2.... They STILL CHANGE @ as well!! Love seat memory but they need to put a LOCK BY fingerprint ON SEAT MEMORIES!!!!
