Awesome info I will have to do some researchGreat question Patsy1099!!!!
andyc16,
I am sure it is doable but to what extent cost wise worth/value along obstacles/procedures to make it happen as well.
Just off top of my head few things I can think of that may come into play---
-seat powered? YES--(patsy1099 again good start point!!!)
-harness there? should be see part info below
-Part/Switch needed for side seat panel? 68233963AB -do you need to change out side panel on seat? I don't think so/appears to have same as powered seats?
-code for dealership to activate/flash to work??? LEQ/Le5 not sure
-Is key fob same or need upgrade??? I don't know
I don't have the memory seats either so I don't know all the functions, key fob memory/if it has memory keys somewhere else. Biggest battle is that part above seems to be the same part in the Limited so it has the function, just not turned on.
Hopefully others can chime in to help!!!
Part info for seat---
Limited seat part:
https://www.moparpartsinc.com/a/Ram...8/_52016_7589054/Switches--Seat/i2381567.html
Rebel seat part:
Sent from my VS996 using Tapatalk
