Can’t clear ABS Light, Traction Control, Check Engine Lights
Slink21
I have a 2021 Ram 1500 Limited Longhorn eTorque, and when I changed the battery recently I got lights for ABS, Traction Control and Check Engine.
I owned a 2019 1500 and I’ve seen the lights same lights come on after a battery replacement but they would clear shortly after.
With the 2021, I’ve taken it to a trusted mechanic and they can’t find anything wrong but couldn’t clear it. They advised me to take it to the Dealer for them to plug into it and see if it’s a software issue.
Has anyone else had a similar problem, and if so how did you resolve it?
How long has it been since you put a new battery in?
I resolved mine by repairing a broken wheel speed sensor wire.
You can not clear those faults from the ABS module without bypassing the security gate way.
If they pop up every time you start driving the truck, then the condition causing them is most likely on-going.
What DTC`s are being thrown?
I have the same problem with my 2021 1500 etorque, changed the 12v battery and traction, engine, anti skid, all are on seems like its not communicating with the can bus anymore, checked all the fuses. Tried disconnecting batter for 30 minutes, cleared all codes but everything comes back. Drove it 40 miles, no change. Any hepl would be appreciated.
You checked all the fuses inside and out?
I have the same thing happening: a dead battery. I replaced it with the AGM, and all my warning lights are on. I went to the dealer, and they cleared all the codes, but all the warning lights are still on. I'm waiting to get it into the dealer for a diagnosis. Any suggestions?
read this
Any luck fixing issue? I am currently having the same problem
