Can’t clear ABS Light, Traction Control, Check Engine Lights
Slink21
I have a 2021 Ram 1500 Limited Longhorn eTorque, and when I changed the battery recently I got lights for ABS, Traction Control and Check Engine.
I owned a 2019 1500 and I’ve seen the lights same lights come on after a battery replacement but they would clear shortly after.
With the 2021, I’ve taken it to a trusted mechanic and they can’t find anything wrong but couldn’t clear it. They advised me to take it to the Dealer for them to plug into it and see if it’s a software issue.
Has anyone else had a similar problem, and if so how did you resolve it?
kdoublep
USA
How long has it been since you put a new battery in?
kapinallinen2
5thGenRams Supporter
Southern Maryland.
I resolved mine by repairing a broken wheel speed sensor wire.
You can not clear those faults from the ABS module without bypassing the security gate way.
If they pop up every time you start driving the truck, then the condition causing them is most likely on-going.
What DTC`s are being thrown?
