1BADRAMLIMITED
It’s been nice to have in the bed. Recently had to cut a tree down and it took the abuse really well and cleaned up like new! @LasfitOffroadAlmost looks like the 3D Maxpider floor mats which are great!!
I'll be putting in the Bedrug, but this might be a nice little addition...It’s been nice to have in the bed. Recently had to cut a tree down and it took the abuse really well and cleaned up like new! @LasfitOffroad
I didn’t go bed rug route because I often load mulch, trees and lumber into the bed and in the past had issues with all those things getting stuck in the fibers of those styles of bed covering.I'll be putting in the Bedrug, but this might be a nice little addition...
Yeah I found out 1 ChristmasI didn’t go bed rug route because I often load mulch, trees and lumber into the bed and in the past had issues with all those things getting stuck in the fibers of those styles of bed covering.
Artificial tree or what lol?Yeah I found out 1 Christmas![]()
One and only time we had a live tree that we cut down. Them damn needles......Artificial tree or what lol?
had a bed rug on previous truck and my wife wanted to go get flowers and such for fall and while we were there she decided she wanted bundles of hay, needless to say it took me a while to vacuum all that crap out.One and only time we had a live tree that we cut down. Them damn needles......
I almost went with the bedrug, but I'm happy with the $90 option for now. Plus it has that carbon fiber look!I'll be putting in the Bedrug, but this might be a nice little addition...
Is it heavy enough to stay in the bed without a cover? Maybe use some of the bedrug Velcro to hold it secure if not heavy enough?I didn’t go bed rug route because I often load mulch, trees and lumber into the bed and in the past had issues with all those things getting stuck in the fibers of those styles of bed covering.
I would say yes BUT would i bet my check on it, NOIs it heavy enough to stay in the bed without a cover? Maybe use some of the bedrug Velcro to hold it secure if not heavy enough?
Well, it drops in from the top, but the pump is submerged at the bottom of the tank on the fuel pump assembly. Which includes the filter, the pressure regulator, and level sensor.So, technically the pump assembly is mounted on the top side of the tank and draws from the bottom. So it could be that there was water in the gas and when it reached the lower level of fuel there was too much water remaining.
I am old, and I remember water in gas causing major damage to cars before the modern fuel tank and fuel pump designs. But water is still not good to have in your gas tank.
Exactly. But water may explain why it happened as the level went down. When the level dropped closer to the pump the water to gas ratio may have been enough to cause the issue.Well, it drops in from the top, but the pump is submerged at the bottom of the tank on the fuel pump assembly. Which includes the filter, the pressure regulator, and level sensor.
Fuel floats on water. They don't mix. If there was water in the tanks it would have been at the bottom and the first thing sucked up.Exactly. But water may explain why it happened as the level went down. When the level dropped closer to the pump the water to gas ratio may have been enough to cause the issue.
Maybe, but I think there could be residual water in the tank even knowing that this is true. The other possibility is that the pressure sensor was acting up. I also wonder if bad gas has a higher density than good gas. Not sure how that would be understood.Fuel floats on water. They don't mix. If there was water in the tanks it would have been at the bottom and the first thing sucked up.
There could have been something else in the fuel, or additives that separated. This brand just recently got their Top Tier rating, so maybe they havent quite figured out their additive package yet. Either way, I'm never going to use that brand again. Should have never even given them a chance. But I will own that decision.Maybe, but I think there could be residual water in the tank even knowing that this is true. The other possibility is that the pressure sensor was acting up. I also wonder if bad gas has a higher density than good gas. Not sure how that would be understood.
It has to have some sort of explanation. At the least there had to be something to cause a bad sensor reading or maybe fuel pressure dropped.
Yea my last truck
When I look into the box of my truck and see what my Line-X coating looks like just from dust gravel roads and periodic water from rain or the car wash that gets in even with a cover, I’d cry if I had a bed rug.I didn’t go bed rug route because I often load mulch, trees and lumber into the bed and in the past had issues with all those things getting stuck in the fibers of those styles of bed covering.
You can clean the Bedrug with a pressure washer as wellWhen I look into the box of my truck and see what my Line-X coating looks like just from dust gravel roads and periodic water from rain or the car wash that gets in even with a cover, I’d cry if I had a bed rug.
For me, it’s way easier to clean out periodically with a broom and my pressure washer. If I have to haul something precious, I just throw in a moving blanket.
