ReadyLift 2in level long term
I drive to costco and back on saturdays.
Then you dont belong in a truck let alone wanting to level/lift it. a SUV would suit you just fine. Your ego as a man is killing you. Spacers are garbage period. You can afford a 50-60k+ truck, you can afford the "budget" strut leveling kit.
Wouldn't the added length from the spacers be equivalent to the added length of the bilstein? I guess obviously without the full travel capability. Or am I missing something about the angle on other components?
no. all it does is pushes everything down to achieve that "lifted" look. your shocks are now your bump stops.
Forums are often filled with enthusiasts who have how shall we say strong opinions 🙂
well some of us are here to give out free information that is otherwise learned by paying a hefty tuition through broken truck, broken parts, premature wear, etc.
at least i'm here to offer that. too many times i see people with broken truck or premature wears on stuff and i'm like... "i told ya so"
"i told ya so"
This right here.
"I put hockey pucks on my suspension to level it b.c i wanted to look cool, put bigger tires, but wanted to be a cheap ahh and save money and now im having issues with _________, please help"
You leveled/lifted your truck the cheapest way possible and your surprised? Who would have thought. Makes no sense to me.
Absolutely, I didn't mean it in a negative way, I think your contributions are some of the best I've seen when it comes to actual suspension modifications here.
Just trying to take a little bit of the edge off the OP on why some of the opinions are as strong or negative towards his question.
oh no i get it hahaha
i mean, we all gotta start somewhere! hell my first lift kit in my life was Bilstein 5100s before i started turning wrenches. i did my research beforehand and although I wanted Kings I was too broke to afford them until I blew the Bilsteins :LOL:
part of me wanted to get spacers and call it a day, but my friends (who are not in the truck scene and don't offroad but they're in the JDM show scene for 20+ years... these are the guys with legit Varis GTR, Evo 8, RE雨宮RX7, etc and worked with SuperStreet, Toyo, and judged various shows) were being so negative about it (calling it poverty spec and even "do not ever bring that out if you do spacers. we don't hang with the people who run fake things") that it actually steered me into the correct direction. to this day, i still appreciate they did what they did so 1. i didn't waste my money and 2. i didn't fu*k up my rig by doing mickey mouse things.
tough love works, i guess lol
To answer your question @tkee, I have 2" spacers (not pre-load spacers) and Rough Country UCA's on my truck. Spacers have been on for 55k miles, and the UCA's have been on for 20k miles with mild off-roading. As long as you're not doing really aggressive off-roading, any billet aluminum spacer will hold up fine. I did not see a reason to replace perfectly good OEM components (springs and Bilstein reservoir shocks) with $5k+ worth of suspension parts for the use case for my truck.
Just make sure you get an alignment any time you change or adjust suspension components, keep an eye on your tire wear, know the limits of the components you've put on your truck, and they'll hold up just fine. I'm not rock crawling or dirt racing my truck because it's not built for that. I take it in the woods every now and then.
Hey man - Which Rough Country UCA are you running? The ones they market as OE upgrade or the 3 - 3.5" lift ones? I'm going the spacer route as well but still want to upgrade my UCA.
The 3-3.5". I have a total of 3" up front. OE would have the same results as running the OEM arms and the ball joint would fail eventually.
To the OPs questions or should hold up fine for normal use a mild off roading. Even top hat spacer levels are good enough for this.
Definitely wouldn’t go Baja with either
$300 leveling Bilstein 5100
$150 Mopar ORG control arms
$100 alignment
I thought that was the “budget” lift… but hey what do I know it’s not like your driving around in a $40k+ truck?
Spacers are junk either level with struts or leave it alone
You don't have to spend big money on suspension components unless your driving style or wants/need say other wise.
I didn’t include install cost since you either pay a shop or pull out some very basic mechanical skills and do it yourself.
Is that a good lift to go with?
Yes that is. Bilstein is one the best/most popular leveling kits on the market. Reputable and reliable. As for the UCAs, yes thoughs are good as well.
$100 alignment
I know this is a little late but I can't find the org control arms on the Mopar site, I only see the stock ones. Does anybody know if they still sell them separate from the kit and if so could you post a link? I would really appreciate it!
2” offroad ones are what you want not the ORG package ones which I learned not long ago are the same regardless of how the trucks optioned.
