So what would be better timber grove oer the airbags that go inside the springs ? This is the first i heard them having issues.
What is these issues iam reading about in this thread, about making it a rougher ride ?2 different products. Depends on what outcome you are looking for. The bags that go inside the springs do not raise and lower the back of the truck. They expand inside the spring to keep the spring from compressing as much. You would need to add air to them before you add load to the truck. If you add the load before airing up the bags, the springs will compress causing the rear of the truck to lower. Adding air after the fact will not do anything because the bag is just going to expand inside the compressed spring. The Timber Grove bags can be aired up and down after the load is added to the truck. This will raise and lower the back of the truck and allow you to adjust the rear height to whatever you want. Timber Grove is an excellent product and I highly recommend them. Product support is the best you will find in the business.
Had my Timber Grove setup for over 1.5 years. Haul a minimum of 1000# tools and material every where I go (never leaves the truck). Haul trailers with everything from scissor lifts to large transformers that push the GVW of my truck to the max. Zero issues. Really quick google search and i didn't find frame a mention of damage claims. it would be interesting to know what to look for.
				I get what you're saying but your lack of issues doesn't cancel out those that bent their frames. Some get lucky, some don't.
I can point to an exact thread on a different forum but I won't because these 2 forums don't really like the "cross polinization" shall we say. Just google it, I assure you the reports are there.
I get what your saying. But, As an extreme use case myself who cant find a single mention of it elsewhere I'm rightfully skeptical and interested to see more. Your the only place I've heard this among many positive experiences that can be found. If you can't or won't bring receipts that is not a problem. I'll assume its malarkey and continue to work the truck as I have been. If the frame goes to crap I'll pull the good stuff and throw it in a 55 f100 I have in storage. Wouldn't that be fun.
I have a one inch lift in the back , motofab spacer between spring and axleTimber Grove offers a coil replacement kit (CRM’s) for factory rake/height. This way you would not have to worry about frame damage. Remove springs, install bags, done.
09'-UP RAM 1500 Factory Rake (STAINLESS) Rear CRM (SQ6027994) — Timber Grove Enterprises, LLC
100% stainless steel bolt-in design that replaces factory coils with 10,000+ lbs. internally dampened Firestone rolling lobe air springs. At ride height air springs consume approximately 28 PSI to support the truck. They provide awesome adjustability, ride quality and off road articulation. Kit inctimbergroveenterprises.com
Yeah thats what i figured i am only towing about 3500 pnds i might just get the airbags that go inbetween springs i dont want a rougher rideIf you wanted the adjustability of the bags, you could remove the spring and spacer, install the bags and air them up to raise it one inch. It will be a stiffer ride though.
Suit yourself, its not that hard to google the other forum![]()
You’ve mentioned this a dozen time and have yet to post a link to any threads/forum where someone has had this issue so others can become aware. It’s always the same response this forum doesn’t like links to other forums etc etc and you can google it yourself. Just link the info let others educate themselves.
I have a 2019 5th gen 1500 Big Horn. I pull a 6x14 V-nosed single axle United enclosed trailer; its under the weight limits, and utilized Timbren SES jounce stops on my Ram. However, one day about 6 weeks ago, I noticed the back to the bed bouncing sloppily while pulling my enclosed trailer. I went to a local body shop and they told me I have a crack in the frame behind my bump stop location on the Frame. Has anyone experienced this before? I called my insurance company and they filed a claim for me under my collision portion. A new frame came from Ram in Michigan, and costs around $4700. The 3rd pic is for reference on my enclosed trailer.
My frame just cracked with only 54psi in the bags. With a 7x16 enclosed. So apparently it's still causing it to crack. And they said I'll be denied for warranty because I have the airbags in there
Credit? I mentioned the cracking as a "public service", do your homework, doesn't matter to me if someone chooses to do that or not@silver billet - I kept saying I couldn't find a google result matching what was referenced. Thank you for proving the requested information. ( @PurpleRT should get the most credit seeing he post the link i needed ). Now it can be discussed and we can maybe learn something.
I've had both the airlift 1000 and sumo springs but not at the same time.Have you ever installed / owned a 5th gen RAM with any of these products? I'm wondering if you have any 1st hand experience or are just trying to help (?) by parphrasing information you read elsewhere. Not a dig - Honest question
I've never heard of a Timbren bump stop helper. They don't work like the products mentioned in the title or anywhere else in this thread. They are also not what I was talking about in any of my posts. Personally yes, I would steer clear from them. Longer and harder jounce stops that will be constantly slamming the rear of the truck together does not sound like a good idea at all.
