I imagine the eTorque uses up a fair chunk of the payload between the drive and the batteries. Mines a 5.7 non-eTorque, 4x4, quad cab Bighorn and my payload by that site is 1,850#. Towing capacity is only 8,310# with the 3.21:1 gears.
Is this using your VIN?I imagine the eTorque uses up a fair chunk of the payload between the drive and the batteries. Mines a 5.7 non-eTorque, 4x4, quad cab Bighorn and my payload by that site is 1,850#. Towing capacity is only 8,310# with the 3.21:1 gears.
I got that with the VIN, but I just checked the door sticker and it says the same. I have to laugh at the passenger capacity...I don't think you can fit three adults in the back of a Quad cab!Is this using your VIN?
1850 is the default payload for a quad cab.
What does your door sticker say?
Just curious.
Awesome. You got a perfectly optioned truck.I got that with the VIN, but I just checked the door sticker and it says the same. I have to laugh at the passenger capacity...I don't think you can fit three adults in the back of a Quad cab!
For payload, maybe, but I have the 3.21:1 gears so it's not perfect for towing - especially with the 33" tires that came on it.Awesome. You got a perfectly optioned truck.
Thanks for verifying. Appreciated.
I did and it confirmed my towing capacities. When I ordered the truck I looked at the Ram website which showed higher towing/payload capacities. Now that I have the truck the capacities are lower. It’s the payload that is preventing me from towing the travel trailer I ordered.
Exactly what options do you have?I have a 22 1500 Limited, 5.7 eTorque, 3.92. towing package, off-road package.
From the door jamb sticker, the max towing capacity is 10,919 and the max cargo is 1,019.
The cargo capacity seems very low to me. I asked my dealer about it but he was no help.
Does anybody else with a similar vehicle have such a low cargo capacity?
Should be nearly 80 lbs.I imagine the eTorque uses up a fair chunk of the payload between the drive and the batteries.
I recall reading somewhere that you hit max towing with an etorque equipped truck. Maybe not max payload though? Could be wrong but the lighter the truck the higher the capacity and towing, among other things.
Still waiting for a member to show up with the Dana Super 60.Yes the 12,750 lbs max towing capacity is only with a 4x2 Quad Cab 5.7L eTorque with Max Tow.
Max Tow includes a larger 256mm (10.0”) rear axle to get you that higher 18,350 lbs GCWR, but that’s buried in the fine print.
They require eTorque on it for marketing. Every other eTorque configuration with the standard 235mm (9.25”) axle comes with lower towing capacity.
Your towing capacity is fine. Like all 1500's it's gonna be your payload that's the problem. Looks like the max your trailer can weigh with all your cargo is 8000 lbs. So what are you gonna take with you? A rule of thumb is tongue weight should be about 13% of trailer weight for safe towing. That's 1040 lbs at 8000 lb max trailer weight. That leaves you about 500 lbs for people and cargo in your truck. A good anti sway hitch weighs 100+lbs and is included in the truck weight, also. Now you're down to 400 lbs for people and cargo. I personally wouldn't go with a trailer this big but others on here have. Obviously there is wiggle room with all my calculations here based on your actual loads.Hoping you guys can tell me if this travel trailer is a safe choice for my Ram 1500. I plugged my vin into the calculator and below are my numbers:
MAX PAYLOAD LB
1,543
MAX TOWING LB
11,320
I'm concerned it may be a tad too big but my wife loves the layout and neither of us would like to go smaller if we can help it. That being said I'm brand new to towing and this will be my first trailer and I want to be conservative and not stressed while towing.
Also included the price, curious if this sounds like a good deal.
As far as us, we have a family of four weighing ~400-450 lbs with a 60 pound dog.
Really appreciate the guidance before I pull the trigger on this one!
You are likely going to be stressed if you are brand new to towing, so just know it's pretty normal until you get a bit of miles under your belt. That's a big trailer behind you at almost 33' and your going to know its there. Price is tough to say because of just all the challenges we are all aware of between inflation, supply chain, supply & demand (RV/trailer sales are on fire)...it used to be a given to get anywhere from 25%-30% off MSRP. I'm guessing those days are over until a lot of things cool off.Hoping you guys can tell me if this travel trailer is a safe choice for my Ram 1500. I plugged my vin into the calculator and below are my numbers:
MAX PAYLOAD LB
1,543
MAX TOWING LB
11,320
Appreciate the input...would it be safe to tow this large/heavy of a trailer or does it make most sense for me to look at smaller? I want to enjoy the trip, including driving to and from the destination, and not be white knuckling it.You are likely going to be stressed if you are brand new to towing, so just know it's pretty normal until you get a bit of miles under your belt. That's a big trailer behind you at almost 33' and your going to know its there. Price is tough to say because of just all the challenges we are all aware of between inflation, supply chain, supply & demand (RV/trailer sales are on fire)...it used to be a given to get anywhere from 25%-30% off MSRP. I'm guessing those days are over until a lot of things cool off.
Towing with the Hemi be ready to fuel up, a lot. You'll be around 8-10mpg depending on where you are (flat vs hills/mountains).
Your truck will pull that trailer no problem, and with a properly set up WDH and a balanced load it wouldn't be too uncomfortable.Appreciate the input...would it be safe to tow this large/heavy of a trailer or does it make most sense for me to look at smaller? I want to enjoy the trip, including driving to and from the destination, and not be white knuckling it.
New to this forum and looking for some solid answers, since the intertubes are full of witchcraft and hobbits! I'm driving a 2021 eTorgue 5.7 Hemi Limited, fully loaded, 5.5 foot bed, 3.92 rear, air bags all around. I love this truck as it's the most lux vehicle I've ever owned...bought it used last September. My dear bride decided this past March that we need a camping trailer....a Northern Spirit 2659bh Ultra Light.This is the discussion thread for towing a camper.
I was asked to sticky a conversation i had as alot of info is lost in internet sorcery.![]()
So you want to tow a camper!
The first thing you need to do is decide which camp you fall in. The best camp to be in is to own neither the truck or the camper. This allows you to research and keep feelings out of your decision. This allows you to easily sit back and learn the process. The next camp is owning the truck or...5thgenrams.com
Discuss freely here. Any questions or comments can be hashed out here.
Have fun.
