- Apr 11, 2019
If your truck is a 2022+, did you install the correct tailgate latch and wiring?Hm. Found both settings and still no ajar notification.
‘23 with the electronic tailgate release button on the upper console, guess I thought it might just be a setting. Is a harness required just for the ajar notification?
Yeah. My mistake then. Since the bed LED’s come on when the tailgate is opened, I assumed the BCM would see this and trigger the message.![]()
Tailgate Ajar Warning enabled?
Hey all! I have seen it mentioned that if you have “AlphaOBD” and some sort of adapter you can enable the tailgate ajar warning. Has anyone done this on a tradesman or base big horn? I really need to get this done but do not no where to start. Thank you for the help!5thgenrams.com
Same with the 8.4 on the horn honkI think horn with remote start can be turned off without jscan. I haven’t done much else myself.
I did change when the tire pressure will alert you that it’s low.
U see the words “THIS” in all caps with an underline , if you click on the word it will direct you to the product the OP is referencing.what cable. I don't see a link or info?
I tried on my phone and it didn't do anything, worked on. my computer. Thank youU see the words “THIS” in all caps with an underline , if you click on the word it will direct you to the product the OP is referencing.
Weird I was able to do it on my iphoneI tried on my phone and it didn't do anything, worked on. my computer. Thank you
Anyone ?2024 3500 mega
Went and performed a test on the air suspension compressor and now I have a service air suspension warning that I can’t clear
How do you calibrate the rear air
And how can I clear the service light ?
Is this a trip to the dealer ?
im not sure about jscan or alpha but there are videos on youtube of people removing a fuse from the fuse box disabling that function so that can do some burnouts etcWith Jscan or Alpha is it possible to allow the traction control to be completely turned off irrespective of whether you are in 4WD or 2WD?
Yup. Fuse.im not sure about jscan or alpha but there are videos on youtube of people removing a fuse from the fuse box disabling that function so that can do some burnouts etc![]()
According to Jimmy, you have to connect as a 2500 or Jeep Gladiator to do the programming. See this post:I was able to read my pin with Jscan but there is nothing to select when I go into the menu to program a key for my 19 DT
With a splitter, you can connect two reading apps or one reading and one writing , two writings will not workIs it possible to hookup a Taser DT and a Bluetooth OBD2 dongle at the same time?
There are OBD2 splitters on the market, so you can attach two OBD2 devices at a time. I suppose I’m asking if there’s an equivalent for the security gateway connections
Why would one want to do such a thing? In my case, I want to take advantage of some of the “live” Tazer feature (in particular, keep front camera feed on screen) while also viewing live stats from JScan (in particular, battery temperature and current).
I suppose my dream device would be a Tazer that also works as a Bluetooth OBD2 scanner.
