TheWaterman83
- Dec 31, 2021
Thanks, been busy too. I experimented with changing the sides and orientation of the sway bar bushing brackets and found one that significantly cut back on but hasn’t totally eliminated the noise/rattle/clunk with Moog bushings.
The first time I changed these out my 4 year old was “helping” and grabbed the brackets so I didn’t get to keep the original configuration. The only thing I noticed was that it was better with the bracket that has more numbers on the passenger side; oriented so you can read them if you’re under the vehicle with your head pointed towards the drivers side. The drivers side was the same orientation but with fewer numbers stamped. I have no clue if that’s consistent from one pickup or trim level.
From my understanding, the opening to slip them over the bar should point towards the front of the truck. As for the brackets, I'm not sure. But I believe I read somewhere on line that the front and rear bolts actually have different torque specs? I could be wrong.
What I will say is the universal brackets seem like there is no difference from one side to the other. I think it might be overcomplicating things. The one thing I do know, is there seems to be a lot of confusion as to what size the bar is and what size bushings to get.
