Asphalt_slayer
Thanks!It won’t. Because it uses the stock knuckles.
If you want the drop spindles, you would need the wheel hubs for a RAM w/ 20's for the Belltech spindles. Others have done it.Dude I love your 2/4 drop. I’m comparing Belltechs kits to yours and Belltechs website says that their lowering kits aren’t compatible with the stock 22in wheel setup because of the larger wheel bearing assembly. “RAM trucks with OEM 22” wheels require a larger bore steering knuckle”. My ram has stock 22s….any idea if the kit you pieced together will have the same issues? Thanks for the feedback and great write up.
For any of y’all, did you have any problems with the exhaust hitting the pan hard bar bracket on the drivers side? I have the borla type s and it sits on the bracket.
