Rebel only tire size referral
Vulpes
West Coast
This website might help, it is a calculator with visuals for wheel and/or tire changes. It helped me make some decisions with modifications to my Rebel.
You'll need the following rim information from stock Rebel rims (FYI I took this information directly from backside of my stock Rebel Rims):
Rim diameter: 18"
Rim width: 8"
Backspacing: 19.05mm
Wheel Offset Calculator
Redz72
Langhorne, PA
295 is the widest I would go on the stock rim. Mine clear the upper control arms but wouldn’t want to get any closer.
Wow that is way too close for comfort. No doubt there is some rub when taking curves like an on/off ramp. I’m not saying take the curves at Ferrari speeds, but tires have give and movement under stress and it’s only a matter of time before that causes damage.
Dewey
WI
Been driving hard and so far no issues. It looks much closer than it actually is. There’s just under a 1/2” of clearance. Stock was .800” clearance.
I’m sure a different style of upper control arm would give a bit more clearance compared to the stock one but I’m not real worried at this point. I’ll be watching closely for any rubbing but doubt it will unless the air pressure is very low.
Redz72
Langhorne, PA
Right on man! I probably just judged the picture wrong. I should know that because I take 12 pictures at a clip and only 1 pic comes out looking the way I want . 🤣🤣.
limechallenger
Looks like a small wheel spacer could help that situation
limechallenger
So ,I got the Cooper Discoverer AT3/XLT in 295/70 /r18, they ride nice and quiet, NO RUBBING, and definitely fill the wheel wells ! So far I like them!
