Rebel only tire size referral
Ok , so I've searched and searched this forum for a clean answer ,and most threads go off point very quickly! What I'm trying to find is advice on maximum tire size that will fit a STOCK NON AIR SUPENSION 2020 REBEL. My factory Dura tracs are about done, and I want to put the tallest, widest all terrain tire on without needing to level or lift my truck. Please only respond if you have a Rebel!
Thanks!
295/70/18 no mod no rub. Bridgestone Dueler AT/Revo in that size is same weight as 33" DuraTrac if mileage matters. All around traction and wear is good. Just a thought from experience.
Such a fantastic and underrated tire. I’ve had all the usual suspects and that is my favorite.
New user here hopefully not going to get grilled lol. I have rebel wheels and tires on my 2024 4x4 Laramie no ram box or multifunction tailgate. Can I go to a bigger size than a 275 without lift or spacers? Or am I stuck with 275’s?
Planning on going with BFG K03. Like the OPs thoughts, which has better clearance a 285/75R18 or 295/70R18. 275 is a little taller and narrower, less Poke at 34.8 tall x 11.3 wide, while the other is shorter and more poke at 34.3 x 11.8. stock is 33.2 x 11.0 so 285 3/4in circumference and an 1/8 inch poke vs the 295 at 1/2in circumferance and 1/2in poke. UCA is tighter on the 295/70. Either way, I will lose the muds. Does anyone have experience with these K03s on a stock Rebel? Thinking I would be open to a 1/4 shim spacer on the 295 if needed. Hoping airing down to 25 lbs will be an option.
I run 285/75/18 with front leveled and .75 spacers in the front and 1.00 spacers in the rear. No rubbing whatsever.
Where the spacers required? It seems that the new tire would come in 1/4 inch. factory clearance is 5/8 to 3/4 inch. Still room on the inside. Height might bring it into the well when at full turn. Love to know in the real world.
what is the actual size?
thinking of 285/75R18 on a bone stock 2020 rebel 1500
Go here.
Go to tech specs at the bottom. Expand it to show more info. Put in your size and get all the data for any of them, but there aren't many listed.
FWIW I went with Falken Rubitrek. Awesome tire. Very nice riding and quiet for an AT.
295/70R18 & 285/75R18 on stock wheels. Most report zero rubbing in daily driving. Most require a 2-inch front lift to clear 35's and still need trimming in the rear of the front wheel well. Wider tires on factory wheels put the tire edge very close to the upper control arm.
This is a quick summary of what I've read on this forum over the last 3 years.
If you're willing to swap in Thuren Front UCAs, you can run a 35x12.5" on a factory OEM +19mm wheel and not rub the UCA...⤵️
Screenshot_20251213_083657_Samsung Internet.jpgScreenshot_20251213_083644_Samsung Internet.jpg
I'm running these UCAs with a +1mm offset and the clearance is huge!
Late to the party, but I’ve seen quite a few Rebels on stock non–air suspension running 285-65-20 with no rubbing, and some even squeeze in 35-11.50-20 with just minor plastic trimming. If anyone here has tried a true 35 on the 2020 setup without trimming, I’m curious how it went.
